Long time project
- TerryK
Long time project
05 Aug 2009 13:34 - 05 Aug 2009 13:37
My 77' 1000 is not really a project, but I'm always looking to change and improve things so maybe it qualifies.
It's in drag race trim in these pictures because I just got back from a 3 day race weekend.
I've had this bike for 26 years and it was pretty much stock when I bought it, except for the pipe. Over the years I've added a 1075cc Wiseco kit, 34mm flat slide Mikukis from an 86' GSXR750, Dynojet kit, Barnett clutch, Accell coils and wires, Dyna S ignition, WM6 Akront rear rim, GSXR swingarm, caliper and rotor, (adapted to the stock KZ hub), and I welded shock mounts on to keep the retro look.
The future holds a late model Gixer front end, swingarm, wheels and brakes, and more motor work of course!!
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 05 Aug 2009 13:37 by TerryK.
- PLUMMEN
Re: Long time project
05 Aug 2009 13:37
nice old classic hotrod!
- Z1109R Fin
06 Aug 2009 03:32
Hi TerryK!
This is one of the very, very few times I´ve seen those Mikunis in a Kwak. I got those in mine, they are TM33-8012 -flatslides. Did Canada get those Gixer750´s back in the ´80s? Nobody seem to know about those carbs.
What´s yor experience of those? Easy to dial in? How´s your low-end, smooth or rough? Mine are pretty rough running below 3krpm but above that run very well and lots of power.
Z1000R ´83...Slightly modified...
- TerryK
06 Aug 2009 06:55 - 06 Aug 2009 07:01
Z1109R Fin wrote:
The first GSXRs actually landed in Canada BEFORE most other countries, including the US. I managed to find a shop manual for tuning the carbs but it still took a long time to get them right. One thing I did find was, I had what looked like a lean condition at first so I kept going up on jet sizes. Turns out I was going the wrong way. The bigger jets were causing the plugs to be "washed" and it looked just like it was too lean. I ended up dropping a bunch of sizes and it came around nicely.
After much tweeking, they run smooth and crisp from off idle to well past red line. I did lose a bit of low end torque as I believe they are a bit too much carb for a basically stock engine, but they pull hard as hell from 4k and up. A set of cams is in the works and it will wake up the engine considerably.
I believe I have all my jetting specs written down somewhere. I'll have a look for them and pass them along. If I can't find them, I'll get all the info next time I have them off (soon). If you have roughly the same elevation where you live, it should work for you.
Hi TerryK!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 06 Aug 2009 07:01 by TerryK.
06 Aug 2009 07:15
terryk,
i like your bike,very purposeful looking.keep us updated on the mods.i have a wiseco pipe like yours on my z1r that my dad bought new in the 80's.you don't see them very often,and you can get the oil filter off which is nice.
thanks for postin,
leon holmes
here is my z1r with the wiseco on it.
thanks for postin,
leon holmes
- TerryK
06 Aug 2009 07:27
531blackbanshee wrote:
Leon,
I LOVE The Z1Rs. My friend has a mint black one with a big bore and 33 smooth bores. What kind of swingarm and rear wheel do you have on yours? Looks cool!
terryk,
thanks for postin,
leon holmes
Leon,
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
06 Aug 2009 07:43
thanks for the compliments i built the swingarm from 4130 .065 wall 1" cro-mo to house a 2000 r1 rear wheel and brake system.i built my own offset countershaft sprocket to convert to 520 chain and sprockets.here is a pic before the x-brace in the front and the chain notch for clearance.
leon holmes
leon holmes
06 Aug 2009 07:54 - 06 Aug 2009 07:56
and here is one of the swingarm after i pulled the wheel for some new brakes.here you can see the x-brace in the front and the notch for the chain along with the sliders i built to keep the chain off the tubes.it works really well and is very rigid.
leon holmes
click the white box and the pic will show up :huh: .
leon holmes
Last edit: 06 Aug 2009 07:56 by 531blackbanshee.
- TerryK
06 Aug 2009 08:14
That's some really nice work there Leon.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
06 Aug 2009 08:20
thank you sir,falling into corners and rolling on the gas and not feeling the back move(skip)around makes it all seem worth it somehow :laugh: .
leon holmes
leon holmes
- TerryK
06 Aug 2009 08:58 - 06 Aug 2009 09:20
Lol, for sure! My swingarm swap was inspired by me following a friend on a 900 into a corner and actually SEEING his rear wheel go a few degrees off center. Scared the crap out of me!!
Here's a picture with the suspension back to normal. (but still with the slick)
leon holmes
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 06 Aug 2009 09:20 by TerryK.
06 Aug 2009 11:12
your bike has a great look to it.if it was mine i would probably think i wanted to change something but wouldn't be able to figure out what.maybe a short ltd front fender and a stock type decal set,thats it.i got nothin,great bike,killer stance with the shocks on.upon further investigation i don't think i would chnage a thing,simple effective i could look at it for hours.
how do you like your steering damper?
what brand shocks do you have ?
is the frame gusseted?
will you be using irishwills tripple trees to convert to the gixxer frontend?
what wheels when converted?
did the swingarm make a noticable difference in handling?
sorry for all the q's,but i need to know things.hehe.
leon holmes
leon holmes
