750 cafe racer
  • thompsonmx100
  • thompsonmx100's Avatar Topic Author
Re: 750 cafe racer
28 Nov 2009 12:45
#336294
Well I have busy stripping my engine. I used glass bead. It worked well but if I had to do it again I would use baking soda. I have spent all week cleaning and I'm still a little worried. But with that said I am witing to get some parts to finish assembling the bottom end. I have however finised painting my clutch cover, oil pan and I smoothed and painted my valve cover. looks pretty good.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: 750 cafe racer
28 Nov 2009 13:47
#336303
VERY NICE!!B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • thompsonmx100
Re: 750 cafe racer
28 Nov 2009 13:56
#336306
Thanks I used Duplicolor high heat gloss black. I hope it holds up. It seems like it is thick. So hopefully its strong.
1985 gpz750
Kz 650
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: 750 cafe racer
28 Nov 2009 18:24
#336360
i think the key is to make sure that it is perfectly clean fist, then try to apply the paint as thin as possible. the thicker it is the easier it chips.
I sandblasted my parts,then washed them with thinner. after painting i found the chipped easy. so i blasted them and started over. as it turned out , the cheap thinner i used to clean them left a film, witch deterred the paints adhesion. the second go round i cleaned the parts with acetone. it worked well.
i used the Dupicolor satin black eng paint.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • thompsonmx100
Re: 750 cafe racer
28 Nov 2009 18:27
#336361
Oh so you used the same paint just different color.Is it holding up well? I used ppg grease and wax remover on all the pieces. I seem to have pretty good adhesion.
1985 gpz750
Kz 650
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: 750 cafe racer
28 Nov 2009 19:07
#336381
Yes it's holding up just fine. the beauty of this is u can just spray a dab of touch up if u need too.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: 750 cafe racer
30 Nov 2009 20:11
#336772
mark1122 wrote:
VERY NICE!!B)
Yep!
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • thompsonmx100
Re: 750 cafe racer
01 Dec 2009 17:15
#336916
Thanks I have it torn down again I'm gonna finish the frame this week then that will be done. Still need to get the subframe welded up. Just trying to get cheap stuff out of the way so i can save some money for the motor bits. It's coming along pretty quickly. I am having trouble staying busy I just have all these loose ends that kinda overlap each other so it's tough trying to just get things finished.
Peace
Travis
1985 gpz750
Kz 650
  • thompsonmx100
Re: 750 cafe racer
09 Dec 2009 17:49
#338299
well I reblasted my upper cases and tried to paint them tonight but the weather was messing with the paint I'll try again this weekend. So I moved on to mounting my rearsets. I have them half mounted I just drilled a hole then welded a nut over the top. the bottom will have a threaded plate made and welded to the frame. but heres some pics of it.
1985 gpz750
Kz 650
  • Gomer
  • Gomer's Avatar
  • I crap worms that look like spaghetti
Re: 750 cafe racer
09 Dec 2009 19:18
#338307
The metal you used for the structure under the seat; square tube? What specifically?
  • thompsonmx100
Re: 750 cafe racer
09 Dec 2009 19:23
#338312
Its an aluminum cr 250 subframe
1985 gpz750
Kz 650
  • Gomer
  • Gomer's Avatar
Re: 750 cafe racer
09 Dec 2009 19:27
#338313
Holding the seat up?
