KZR's Bikes of the Month for 2025
Gasoline goes bad with time and begins in as little as 3-4 weeks. This effect is known as varnishing. Jets and passageways within carbs become obstructed when varnishing occurs.
Liquid gasoline changes chemically into a gel like substance. Advanced stages of varnishing results with the solid gel changing into a crystal powder substance. Interior carb surfaces are etched in the process and may require carb replacement.
The choke and pilot circuits with most motorcycle carburetors share passageways. When pilot jets become obstructed, the choke circuit compensates and allows engine to start and idle with choke, but stalls without choke.
See my tech files “Carb Cleaning 101 & 102” for details on repairing this common problem.
Motorcycle News
RideApart - Articles
Find a feed you like and subscribe. RideApart.com
If you like KZR Please consider making a donation. Thank you.
KZRider is free, but not without cost.
Please consider chipping in a few bucks to help cover the cost of running the KZR servers.
