I was riding my fuel-injected kz1000G1 "Z1 Classic" and was shocked to have the bike die on me again.
I had a new fuel filter to install so I decided "this is a good time to install the new gas filter."
THIS FILTER IS HUGE -- no junk from the gas tank will get by this stock fuel filter, I can say that with 100% confidence:
I looked at the fuel pump and the hassle of removing it from the bike in order to inspect it. "Surely that would be a waste of time, look at the huge filter Kawasaki put in the gas line, surely only *clean* gas is getting to the pump. I don't feel like yanking something that I *know* must be fine."
So let's have a look, maybe that old huge gas filter is clogged, and that's why the bike is still dying.
I removed the old huge inline gas filter and poured the gas left inside into a cup -- there was no junk in the gas left in the filter to imply a clog in the filter.
So the old filter is not clogged up, the gas ran out of it fast, and no sediment came out with the gas. Guess I don't need to pull the fuel pump, hassle saved. I turned the old filter upside down, I shook the old filter, I tapped it hard to try to get any loose stuff that might show the old filter was clogged.
The old filter was clean as a whistle.
There's that fuel pump. "I know that sucker's clean. After all the old gas filter is spotless, so no junk got into the fuel pump."
But I had nearly exhausted all other causes of this bike suddenly dying like it still does.
I yanked the fuel pump.
I pulled off the gas line that goes from the output side of the big gas filter to the Input side of the fuel pump.
And I found a filter screen inside the inlet nipple of the fuel pump.
This little filter screen was not mentioned in the fuel pump troubleshooting steps anywhere in the manual.
I called the Kaw shop and asked if they sold this fuel pump's input screen, and was told that "the parts diagram does not even show the input screen -- the Kaw parts list shows the fuel pump as one part, as in 'No User-serviceable Parts Inside.'"
I had to remove the 4 screws on the fuel pump input side and remove that black input cap that has the input gas nipple in order to push the filter screen out of the fuel pump.
That input screen was filled -- with crystallized gas.
I'm not certain but I suspect that clogged input screen was starving the fuel delivery.
I would not have found it except for the highly indignant and rabidly vengeful state of mind I have towards this bike. It's like that hot cheerleader I thought I was dating in high school -- she was a real tease.
Well the filter was stuck solid in the fuel pump's input nipple. I pushed and it collapsed and fell apart:
This input screen is about 1" long and was 1/2 full of hardened gasoline crystals.
If the fuel pump's inlet was clogged -- that would explain why the bike kept stalling as if it lost spark in all 4 barrels simultaneously or as if the computer shut down all 4 injects simultaneously.
I really learned something here. In the 10 years the bike set, by leaving old gas in the line, the prior owner unwittingly compromised the mission of that big gas filter, which was to prevent junk from getting into the pump's inlet. By letting the bike sit so long, the gas itself became the pump's enemy.
Of course the Kaw shop said: "The fuel pump is
No Longer Available and that little input filter screen was *never* available as a separate part, you had to install a new pump."
MY QUESTION IS -- where do I go from here?
I thought about putting an extra inline gas filter between the pump input and the output of the main filter to take the place of the useless inlet strainer, but the service guy at the Kaw shop warned me about 'keeping the flow rate the same.'
Any ideas? This may ONCE and FOR ALL fix my bike.
