- Thank you received: 5
My new 82 GPZ1100 will not start!!! HELP PLEASE!!!
- flhwesty
While waiting I am going to drain fuel. Clean connectors.Take the battery for a load test.
How do I check the fuel pressure from the pump?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- kano
- Not Another Bloody Limey!
- kano
- kano
- otakar
This is were I am at... checked for spark. None on inside cylinders. So I have a set of dyna coils. put one coil on to see if that fixed problem. Then realized I gave wires to a friends last year. Now I will have to order some and wait until next week to continue.
If you order new coils, make sure they are the right ons. They must be 2.2 Ohm not the more common 3.0 Ohm. To check the fuel pressure there is a "T" that you must mount between the pump and injector manifold, to which you mount a fuel pressure gauge. I have tendency to doubt that the main coils are bad. I would more suspect the pickup coils. I used to change those on my 1300 all the time. It is simple to check the main coils. Remove the two wire plugs that feed the coils and put an Ohm meter no those two coil positions. They should measure between 2.0-2.4 Ohms. If they measure far from that than they are bad.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kano
- flhwesty
otakar-How do I test the pick up coils?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- MFolks
- Thank you received: 540
- flhwesty
The connector between the pick up coils and the ignitor was rotten and falling apart. It was probably grounding against the fuel pump. After we cleaned the connection and taped it, we had spark at all cylinders!!!!
I am still going to wait until I get new wires fron Z1 before road testing. Really hope this is all it was.
Thanks to everyone for there input. I knew before posting this morning I would get lots of help. I will post after I get the new wires on.
Again thanks Rob
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
