Advanced Search
Search Results (Searched for: ZRX shocks)
Replied by Sandy on topic ZRX SHOCKS!!!!
14 Apr 2006 18:27
Sandy's Avatar Sandy
Z1R rider wrote:
if all else fails, head on over to the zrx board, you can find take offs for sale every now and then. www.zrxoa.org/
That's exactly where I was going to look...I just assumed He wasn't a Member,and You HAVE to register there to view the forum,and if He wasn't going to need to register and be a Member,then I could do the searching for Him...good call though...and Hansen...there You have it,Bud...if You want to register there,there's a lot of good info on the ZRX's and other models as well.
In the meantime,I'll look around there for You and let You know what I find...B) ...
Replied by bob_z1 on topic ZRX SHOCKS!!!!
14 Apr 2006 16:02
bob_z1's Avatar bob_z1
cjhansen2 wrote:
Hello all,
What I do have is the new old stock konis that I had on the bike. They are in perfect condition
Are you planning to sell the Konis?
If yes, How much????????
Replied by baldy110 on topic ZRX SHOCKS!!!!
14 Apr 2006 15:15
baldy110's Avatar baldy110
I bought a set of ZRX shocks from the a member off the ZRX board last year for $100.00. They sell them all the time on that site. Your bike looks sweet. It looks like you came up with the same style and color seat I put on my 650. Good luck
Post edited by: baldy110, at: 2006/04/14 18:17
Replied by Z1R rider on topic ZRX SHOCKS!!!!
14 Apr 2006 13:40
Z1R rider's Avatar Z1R rider
Replied by cjhansen2 on topic ZRX SHOCKS!!!!
14 Apr 2006 09:19
cjhansen2's Avatar cjhansen2
That would be great! Thanks a lot, guys.
Josh
14 Apr 2006 08:13
Josh...I have a set for My ZRX transformation(fall project),but obviously I'll be using them.I found another set for another Member for a pretty good price,so let Me see if I can dig up a set for You.
Give Me a few days and I'll see what I can find,Bud.B)
(Bill...You read this?...maybe You can have a look around too,Bud)
Post edited by: sandy, at: 2006/04/14 11:15
ZRX SHOCKS!!!! was created by cjhansen2
14 Apr 2006 07:14
Hello all,
Getting down to the end with my streetfighter, just need to wire it, do bodywork, and get the swingarm done. Pics of the bike are at :
kzrider.com/forum/viewthread.php?tid=24367
Anyways, I decided I wanted to put a ZRX swingarm on the bike. I found a swingarm, have done the necessary machining to make it fit, but alas I have no shocks. What I do have is the new old stock konis that I had on the bike. They are in perfect condition and I was wondering if anywone had purchased a pair of zrx shocks and have decided not to use them. I really need a set and they do not come up on ebay very often. Also, if anyone is interested, I may be willing to sell the swingarm that was on the bike. It is a KZ750 swingarm lenthened 4 inches (originally same length as a kz1000 arm) with full length gussets on the bottom. The pivot point of the swingarm is welded in from the KZ1000 to match the KZ1000's wider frame. I used the KZ-750 arm since it allows for more clearance by the front of the wheel. (I had a 180 rear tire in it no sweat).
Thanks,
Josh Hansen
Post edited by: cjhansen2, at: 2006/04/14 10:18
Post edited by: cjhansen2, at: 2006/04/14 10:19
Replied by AHRMA120 on topic ZR-7, GPZ, z750
17 Feb 2006 09:06
AHRMA120's Avatar AHRMA120
The original ZR-7 of the early 90's up to the point where they threw the old zx-7 motor in the frame are essentially the same as kz, gpz motors. The reason the horspower was done is due to EPA milder cams less compression and CV carbs. A zr-7 motor will bolt into Kz Frame except it does not have the lower mounting lug on the cases in the front. Everything else will pretty much bolt over onto a KZ650 or KZ750 including front end. The rear swing arm was mono shock and also about an inch and a half longer. It has no mounting points for twin shocks. Minor problem. The ZRX 1100 1200 swing arm actually will slide in to the stock frame with the exception of a little shimming. It also is about two inches longer than stock. But you can accept bigger rubber. The front end will also bolt right in with some different sizing on the tapered bearins in the steering neck. The problem now becomes frame twisting with all that moder rubber. The Zr-7 stuff is hard to find. A SV650 front end is identical to the Zephyr and far more easy to find. A lot of racers took the stock front end off for a GSXR front end and have them sitting around.
The ZR-7 motor can be spiffed up by sliding in GPZ pistons and cams. Still available. The Zephyr 550 also benefits greatly from simply putting in GPZ pistons and cams. My wifes Zephyr 550 dynoed at 69 horsepower with this set-up. The pistons slide right in and the cams dropped in. We slotted the cam gears and degreed them up. hope this helps.
ZRX 1100 bolt torques was created by barney
27 Jan 2006 17:06
barney's Avatar barney
Hope somebody can help. I'm building an 81 GPZ1100 with ZRX1100 forks,triple clamp,swingarm,shocks,front and rear brakes,and front and rear wheels.
Long story short - I dont want to buy a ZRX manual just to get the specified bolt torques for all this stuff. Can anybody shoot me the torques I need? Thanks.
Replied by Tower_Monkey1 on topic Pictures of my fibreglass seat
09 Jan 2006 08:15
Tower_Monkey1's Avatar Tower_Monkey1
Those shocks look very much like ZRX shocks. Im looking at maybe getting a set for my bike. A tad longer, but a very nice upgrade from stock.... Wayne
Displaying 661 - 670 out of 681 results.
