Advanced Search
Search Results (Searched for: ZRX shocks)
Replied by steell on topic Pressing out rear shock centers?
14 Jul 2006 09:50
steell's Avatar steell
First thing I'd try is pudhing out the steel bushing and then making the center hole in the ZRX shocks big enough to get the bushing in. If you have to remove the rubber bushing, try softening them by soaking in boiling water to heat them first.
Silicone spray will help them go back in easier.
Pressing out rear shock centers? was created by vic44139
14 Jul 2006 09:22
vic44139's Avatar vic44139
just bought some used Zrx1200 kyb rear shocks. trying to put on my 79 kz1000st. however the bottom eye hole-rubber thingy needs swapping out. the zrx ones r smaller bolt hole. whats the best way to get them out so i dont screw them up?
Post edited by: vic44139, at: 2006/07/14 12:37
Replied by z1000d on topic The Great Swing Arm Debate: GS1100E -vs- GSX-F750
11 Jul 2006 09:22
z1000d's Avatar z1000d
Hi all,
The swingarm came off a zr1100
It normally takes a 20mm pin but I made "adapters" that allow use of the stock 15mm pin. Real simple to do.
The frame was checked for straightness, then gussetted & welded. The rear pag triangle was removed. A set of ZRX shocks will work nicely and really dress things up.
It currently allows use of a 160 rear tire. This is limited by the wheel not the swigarm.
ZX9, ZX6,ZRX swaps was created by auggiedog
13 Jun 2006 11:15
auggiedog's Avatar auggiedog
Ok, first post...
So, I've been spending some time around the forums trying to get a feel for what might actually be the best parts for swaps on a 76 KZ900. I think I might be OK with the rear end, at this point i am going to try out a modified GS1100 swing arm with a pair of ZRX piggyback shocks, and the caliper lowered.
What I can't seem to get a good line on is the front end..lot's of posts with has anybody tried this, but only the one fork swap thread (which I see mentioned alot but can not find :woohoo: !
There seems to be a lot of ZX stuff out there, so that's why I mentioned it....
Any help or thoughts about this:S
Replied by Mark Wing on topic lowering a bike
19 May 2006 19:10
Mark Wing's Avatar Mark Wing
dutchz wrote:
Hey waterman. I rode around with dropped forks and zrx shocks for a while without any problems. The bike did turn in a lot easier. I would still be running the ZRX shocks but they looked to damn modern on my bike, trying to find something that looks more vintage. Going back to my 30 yr old stockers was a "shocker" though hehe.
Yes it will turn easier at the expense of high speed stability.
When I'd go to the drags I'd slide the tubes up and put some struts on the back.
Mark
Post edited by: Mark Wing, at: 2006/05/19 22:24
Replied by dutchz on topic lowering a bike
19 May 2006 08:56
dutchz's Avatar dutchz
Replied by wireman on topic ZRX SHOCKS!!!!
15 Apr 2006 08:18
wireman's Avatar wireman
1197 and juice,should be a riot!:evil: :evil: goodluck,happy wrenching!
Replied by indykaw77 on topic ZRX SHOCKS!!!!
15 Apr 2006 04:21
indykaw77's Avatar indykaw77
Yup....it sucks when higher education and silly things like bills, groceries, etc. get in the way of quality wrench time!!
Replied by cjhansen2 on topic ZRX SHOCKS!!!!
14 Apr 2006 22:36
cjhansen2's Avatar cjhansen2
Thanks for all the help, guys. I will try and look in that zrx forum. I dont know on the koni's....I guess I would have to say make me an offer (I know that makes it difficult ;) ). As for my motor, it has a new old stock crank, (picked it up on ebay for $100 hahaha), which has been welded by ape, a ported and polished head, stage one yoshimura cams. If I have problems with the trans I will backcut it, but it isnt now. I also machined the head for the nitrous foggers. It has a 1200 kit in it also. Ill let you know how the zrx forum works for me. ALL I HAVE IS WIRING, THE BODYWORK, AND THE REAR SUSPENSION!!!! I have been working on this bike for 6 years now (in between college and getting a real job), and I really want to get it on the road!
Thanks,
Josh
14 Apr 2006 19:11
ive never been much for the streetfighter look,but damn thats gona look nice when its done!B) ;)im putting a longer swingarm on mine so i can put the bottle on top of swingarm in front of back wheel where its not so obvious.whats in the motor?
Displaying 651 - 660 out of 681 results.
