Search Results (Searched for: ZRX shocks)
Replied by ThatGPzGuy on topic zrx 1100 shocks on GPZ 750
22 Apr 2015 04:23
Yes, but I had to remove the helmet lock.
zrx 1100 shocks on GPZ 750 was created by Jrider
21 Apr 2015 12:03
Will the ZRX 1100, KYB rear shocks fit the 1982 GPZ 750 wit no modifications?
Replied by baldy110 on topic handling 82 gpz750 vs 81 gpz 1100
18 Apr 2015 18:40 - 18 Apr 2015 18:42Jrider wrote: Baldy, just what all was involved in that swap? Sounds interesting.
A lot of work. I wanted the engine to sit as low as possible so I could do regular maintenance so I cut the bottom tubes of the frame and got the engine in really low. I welded the frame tubes back together with tubing slugs inside the tubes for strength. I can remove the top end without any problems. I had to make motor mount tabs and re-design the Kerker pipe to get it to work with the ZRX swingarm. There are a bunch of other small things I had to take care of. I installed a 1175 Wiseco piston kit in it along with WEB cams, ported head and the Mikuni RS36 carbs. I wanted it lighter than the GPZ750 so I really put it on a diet. It weighs in now with full fuel at 420 pounds.
It is a beast, it will rip you arms off when you get on it hard. If I am going to die on a bike this is probably the one that will kill me. It is so fast and smooth that before you know it your at 120 mph and only at 1/4 throttle. It requires a lot of discipline to operate. It handles better than the GPZ750 probably due to the shocks, stiffer swingarm and the lighter weight. Very addicting bike to ride. I give modern sport bikes fits.
Replied by NakedFun on topic custom front sprocket offset
08 Apr 2015 11:11Randombeat wrote:floivanus wrote: I'm running the same swingarm but twin shock and came up with 3/8" with a slightly narrower wheel
And yeah ram had 1/2" offset i believe
Attachment image-2.jpg not found
Not to hijack the thread, but can anyone tell me what shox these are? Would they bolt on to a 1980 kz750h?
Those are EBay shocks. A number of overseas vendors sell those. Just search on EBay for "ZRX Shocks" or "Cafe Racer Shocks" and they'll come up under different lengths and mount types.
Cory
Replied by SWest on topic question for fitting new ZRX shocks to the KZ
06 Apr 2015 08:05
Good to know.
Replied by richrand on topic question for fitting new ZRX shocks to the KZ
06 Apr 2015 08:01
I looked for info online and what I could find was that with gas reservoir shocks, orientation doesn't matter. Very open to clarifications here.
Attachment big_ncr_new_blue_stradale.jpg not found
Replied by NakedFun on topic question for fitting new ZRX shocks to the KZ
06 Apr 2015 04:46 - 06 Apr 2015 08:05
There is nothing wrong with running upside down as the resivior is a nitrogen charged bladder that keeps the fluid in the shock pressurized. The only watch out is that now your compression and rebound adjustments are opposite location you left them! Lol. Either way, it seems you have some other clearance issues to deal with.
Cory
Cory
05 Apr 2015 20:30
I'd be more concerned with the reservoir being up side down.
Replied by spdygon on topic question for fitting new ZRX shocks to the KZ
05 Apr 2015 20:29 - 05 Apr 2015 20:31
Ace hard ware have some plastic bushing u can use to gain the 1/4" u may need
They would go against the frame and arm then slide your shock use one washer then a corn nut.
AlsoI if you want both side to look the same just do the same on the other side
And get 1/4" longer bolts ...also at Ace
05 Apr 2015 20:27
So I flipped the shocks upside down and now it fits great on the left side. On the right side the reservoir hits the brake caliper. So I flipped them around so the reservoir is facing front and the left still fits great (plenty of clearance), but now the spring seat is hitting the rear brake stay. For what's it's worth, the seat hit the stay the other way too, but the contact with the caliper was the bigger problem. Can I get a super thin brake stay?
Displaying 181 - 190 out of 677 results.
