Search Results (Searched for: Acewell)
Replied by baldtire on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 15:11
i just put one on a yamaha seca 750, used the magnetic speedo pickup
it's just the 3200 plane jane model so hooking it up was pretty simple
only problem was the tach jumping all over, i used the original tach wire and put a 1 meg ohm resistor in the wire and all is well
the back light is blue, nice if it goes with your bike
the temp sensor got threaded into a aluminum block that got jb welded to the cam chain tunnel, runs about 180/190
on the 4 lane and goes to 250/270 when it's just shut down
Replied by freebyrd24 on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 11:36
+1, I'd be interested to hear about peoples experiences installing the acewell gauges. I'm thinking of one for my kz1000.....
Acewell Speedo/Tach/Gauge Installation? was created by 1978KZ650SR
22 Sep 2009 06:35 - 22 Sep 2009 06:35
Has anyone here installed an Acewell on their bike? I am thinking of swapping out for one as mine gauges are pretty old and ugly. If so, how was it to install? I couldn't find anything about them in the forum, so I thought I would ask everyone.
Thanks
Thanks
Ignition switch relocation was created by sbulla
16 Sep 2009 14:21
Any of you who have performed this, chime in, send pics, descriptions, etc.
I just installed an Acewell 2803 in place of the stock gauges and am mulling over what to do with the ignition switch. Guess I could just fab a tab and mount it off one of the handlebar bolts but, if possible, I would like to move it away from the tree and, maybe, mount it somewhere else.
Any ideas?
Sonny
Any ideas?
Sonny
Replied by Old Man Rock on topic a digital gauge on ebay
01 Sep 2009 09:09
Oh this question.... :laugh: :laugh:
Review the last couple of pages of my project have the fabbed mounting bracket I needed.... ZX636 front end doesn't have a speed drive so had to go with magnetic pickup on the bracket and one of the magnet bolts on the front rotor...
Acewell does offer a drive to electronic converter....
The picup is required 1/4" away from the magnet during rotations for sensing and accuracies... Mine came in 1.2 mph difference from a buddies brand new jeep cherokee...
For the speed programing, you measure and program into the unit your front tire circumference (not rim circum)... Programing is easy, push buttons on the unit...
For tach, two options... Wire wrap around coil wire Blah or direct hook up into one of the coil feeds... Tach programming has .5, 1, 2 settings for different setups...
Truly not dificult, even for you Sandy... :laugh: :laugh:
Replied by Sandy on topic a digital gauge on ebay
01 Sep 2009 07:32
Hmmmm....interesting stuff.
Rock...what was involved in installing that Acewell,to get all of the functions to work?(Speedometer,etc)
01 Sep 2009 05:19
Best of both Worlds (Analog & Digital) but hose damn Limeys can never get it for sale...
Oops :blush: ,did I write that out loud, meant our English brothers... :laugh: :laugh: :laugh: Sorry Kano and Limey, couldn't resist...
Most probably Electrosports.com for they have been advertising this for over a year now, here next moth... Yeah right....
And yes, I have the Acewell 2802, love it! No problems reading the digital in the sunlight... Accurate little bugger as well.
OMR
OMR
Replied by thompsonmx100 on topic a digital gauge on ebay
31 Aug 2009 22:42
yeah he has an acewell Which was my first choice but now I don't know
Here’s the project:
1976 KZ900-A4 Street fighter modification:
All fabrication, welding, paint, aluminum repair and buffing, engine rebuild, CAM Degreeing, carb jetting and fine tuning accomplished by myself.
NOTE: Cylinder bore & Head accomplished 3rd party...
Motor upgraded to 1015cc.
Wiseco Pistons and rings.
Camshafts: WebCam .365 lift, 283 duration, 246 duration @ .050
Head: Valve 3 way grind with Port & Polish via Larry Cavanaugh @ Cavanaugh Racing Heads. (New SS Valves, Guides & Seals).
Kawasaki ZX636 front end and ZX6-RR rear J link mono-shock rear swing arm.
Clutch: OEM steel & Friction plates, new springs.
OEM oil pump.
Carbs: Keihin, 29mm CR specials, Dynoman Filter PODs
Kerker 4 to 1 exhaust with 1.5" competition baffle.
Dyna S Electronic Ignition and Coils (GREEN 3 Ohm).
Liske Timing components (ALL replaced) & Tsubaki Heavy Duty Timing Chain
Front Rotors & Pads: EBC
Digital Speedo/Tach combo: Acewell 2802 Series
Corbin Seat
Aztec8 Dual 5.25" Head Lights (Thanks Kano!)
Integrated LED Brake/trun signals and LED Mirrors.
Rear Sets: Used Kawasaki ZX-7
Spiegler Black Chrome Braided Stainless Steel Brake Lines.
Tires: Michelin Road Pilot 2 Series
Renthal Low Rise "FAT" Handle Bar w/Triumph Risers
Yamaha forward clutch and throttle hand levers and master cylinder. (Used)
Paint: Dupli-Color Gloss Black Enamel, Metal-Cast Gold and Sherwin Williams 2 part Clear Coat....
Still left to accomplish... Earl Oil Cooler!
I think that's about it... :S
OEM oil pump.
Corbin Seat
Replied by clutch on topic viable options to replace the tach and speedo
16 Aug 2009 22:03
I just ordered my Acewell 2803!!! I'm so excited!!!! Now watch...I won't be able to hook it all up right now....LOL!
Displaying 351 - 360 out of 519 results.
