Search Results (Searched for: Acewell)
Replied by perattzi on topic Acewell Speedo/Tach/Gauge Installation?
23 Sep 2009 18:16
I'll buy your stock tach...if you don't need it.
Replied by 1978KZ650SR on topic Acewell Speedo/Tach/Gauge Installation?
23 Sep 2009 17:54
Yeah I know but Acewell makes a hookup specifically from the stock speedo box on the axle to the gauge. I believe it converts the signal in the line. Has anyone used this?
Replied by baldtire on topic Acewell Speedo/Tach/Gauge Installation?
23 Sep 2009 16:39
it's a electronic speedo so somewhere along the line the cable has to turn into a wire
i thought about putting the wire in a length of vacuum hose
just so it didn't look like a wire
the magnet can go on the rim with some mounting tape and the pickup under the fender if you don't want to drill the rotor
23 Sep 2009 14:23
What about using the speedo drive on the front tire? I know they make an cable to fit it.
Replied by Old Man Rock on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 16:55Replied by Old Man Rock on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 16:54 - 22 Sep 2009 16:54
It's a piece of cake....
Since my OEM speedo Tach was shot.... I cut out the speedo tach harness with ~ 8" to the main harness connector...
Spliced and soldered the indicators from the speedo to the harness conductors appropriately. This way, just plug any play....
For the tach pick up, you have two options...
1) SUCKS ASS... Not accurate.... They provide a small conductor to wrap around one of the coil wires.... Piss poor pick up and inaccuracies in comparison with a DVM tahometer...
2) Direct solder into primary of coil 1/4...
In either case, you have a number of simple programming capabilities for the correct number of cyclinders that can be displayed...
For the speedo, you will receive 2 different size rotor bolts with magnets embedded in them.... Pending your rotor, you can drill and tap a hole for the magnet bolt or ion my case, just used a large washer since I have ZX 636 EBC rotors... See images....
For the pickup, you'll need to fab up a bracket... The pickup is required to be no more than 1/8" from the magnet during rotations.
Programming is simple, measure the circumference of your tires in cm and program in...
Once all completed, compared to another vehicle side by side, 1.2 mph difference! Obviously I could tweak the programming to match but hey, 1mph difference, good enough!
OMR
See next couple sets of images....
OMR
22 Sep 2009 16:08Replied by baldtire on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 16:07Replied by baldtire on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 16:05 - 22 Sep 2009 16:06Replied by timebomb33 on topic Acewell Speedo/Tach/Gauge Installation?
22 Sep 2009 15:21
come on guy's you know the rules we need pictures
Displaying 341 - 350 out of 519 results.
