GS1100 vs GSXR600 Swingarm
  • rpiian
  • rpiian's Avatar
  • Live to Ride, Ride to Live
Re: GS1100 vs GSXR600 Swingarm
10 Jan 2009 06:22
#257067
Supercharged-
What year is that GSXR 600 swingarm?
I was planning on doing a conversion soon and I was just curious.
-Ian
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
  • PLUMMEN
  • PLUMMEN's Avatar
10 Jan 2009 07:50 - 10 Jan 2009 08:10
#257071
well i had a picture of how i modified one of my frames for a gs1100 arm i tried to resize it,now it disapeared!:blink:
Last edit: 10 Jan 2009 08:10 by PLUMMEN.
  • supercharged
  • supercharged's Avatar Topic Author
10 Jan 2009 12:31
#257096
rpiian wrote:
Supercharged-
-Ian
Ian - I am using a 1998 and 1999 for 2 projects. Both are the same. Since they have been EZ to find, I have not had to expand my search to other applicable years.
I am getting busier and have not cut the frame out of the way at this time, but expect to accomplish this by end of next week. At that time I will work on my adaptation of the pivot. I'll be happy to share what I find out.
Keep us informed of your progress ;)
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
  • PLUMMEN
  • PLUMMEN's Avatar
10 Jan 2009 14:18
#257125
supercharged wrote:
gsxr600 lined-up in frame
ya know that hole where monoshock used to go through makes a perfect place for a nitrous bottle!B)
  • rpiian
  • rpiian's Avatar
10 Jan 2009 15:25 - 10 Jan 2009 15:31
#257132
Sick, thanks supercharged. I was going to go with a 99 GSXR swingarm on ebay. It looks like there's little or no modification needed (possibly some easy flycutting/machining?). I will most definitely keep you guys posted on how it goes. However, it may be a couple months before I can bring the bike down to school (Darn VT weather!).
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Last edit: 10 Jan 2009 15:31 by rpiian.
  • supercharged
10 Jan 2009 16:11
#257142
keep in mind the fit is good - a little shim on each side, but the 600 arm will require a sleeve in the pivot bolt.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
  • jezz
  • jezz's Avatar
  • 1981 kz 750e
13 Jan 2009 18:58
#257763
will the gs 1100 swingarm work on a kz750e
1981 kz750e
  • badrhino
  • badrhino's Avatar
13 Jan 2009 20:35
#257774
What about newer ones? Some of the 04-07 are going cheap and they are braced. Some even come with the shock if a guy wanted to go with the single shock conversion. Will these fit?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • badrhino
  • badrhino's Avatar
14 Jan 2009 09:46
#257852
Also, how big of a rear wheel/tire can you go with on the GS1100 arm?:P
Franken Z!
  • PLUMMEN
  • PLUMMEN's Avatar
14 Jan 2009 10:04
#257858
150-160 shouldnt be a problem B)
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
14 Jan 2009 11:02
#257865
If you don't mind a little work you can squeeze a 5.5" rim with a 180mm tire in a Gs1100E arm.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • rpiian
  • rpiian's Avatar
20 Jan 2009 11:41
#259011
Ok guys. I'm really excited so I'll try my best to hold it in. Just got my swingarm today, GSXR 600 '03. Now, I'm going to need a sleeve for the pivot bolt.
I could definitely turn down and drill some aluminum (pipe or billet)... but out of curiosity, is there any aftermarket company that does this stuff?
My goal after that is a shock setup and lastly, the drive and brakes (w/ new wheel of course). Can't wait to get started!
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
