Dyna Coils 3 Ohm Gpz 1100 1984
  • man-of-war
  • man-of-war's Avatar Topic Author
03 May 2018 19:52
#782811
Hi Guys , Just pulled the 1984 Gpz 1100 from storage today, she's been sleeping for 5 Years and I need to treat her with gifts...lol I placed an order today for tires and wanted to install some Dyna Coils on the bike . Could you guys direct me in the right direction on which Dyna Coils to get . I was looking around and all I could find about Dyna Coils for a 1984 1100 GPZ is the 3 Ohm Green dyna coils work. I need a part number so I could order it on line....Any help will be appreciated.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: Dyna Coils 3 Ohm Gpz 1100 1984
04 May 2018 04:04 - 04 May 2018 04:06
#782815
If you are not stuck on Dyna, another alternative is the ACCEL 140403 Universal Super Coil Kit which includes the spark plug wires.
www.amazon.com/ACCEL-140403-Universal-Super-Coil/dp/B001OMKFKS
I have no experience with Dyna, and am not bashing them, but owning my GPz since 2003 I have only had one coil failure.
Steve is right, that is one nice ride you have there.
'85 GPz550(ZX550-A2)
Last edit: 04 May 2018 04:06 by CoreyClough.
The following user(s) said Thank You: man-of-war
  • riturbo
  • riturbo's Avatar
04 May 2018 05:03 - 04 May 2018 05:03
#782817
Nice bike . Hopefully the fuel pump will come on after sitting so long . That seems to be one of the problems with the turbos when they sit . Sometimes you can get them going if you soak them in gas for a few days then put a bat to the connections and cycle it both ways . sometimes you can shock them back by taping it with a hammer .
good luck shes a beauty
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 04 May 2018 05:03 by riturbo.
  • man-of-war
04 May 2018 19:02
#782878
SWest ,thanks for the info. I'll place an order for that set.
  • DFIGPZ
  • DFIGPZ's Avatar
06 May 2018 20:11
#782987
if it still has factory stock ignition Best to use gray 2.2ohm coils.
1984 750 Turbo
  • man-of-war
07 May 2018 05:41 - 07 May 2018 05:48
#783002
I found these Grey coil for the 1984 GPZ 1100..............................- For Dyna 2000 Applications/2.2 Ohm/Dual Output/Grey/2 Per Package
Part#: DC4-1 Availability: In Stock.....
Would I have to buy the Dyna 2000 for the Grey 2.2 Ohm coils to work??
Why cant I use the Dyna GREEN 3 Ohm coil. ....
On the existing stock coils, they read [ 2.8 Ohms PRIMARY ] [ SECONDARY 11,780 Volts ]
www.orientexpress.com/p-13802-dynatek-dy...ey2-per-package.aspx
Thanks
Last edit: 07 May 2018 05:48 by man-of-war.
  • JMKZHI
  • JMKZHI's Avatar
07 May 2018 06:16 - 07 May 2018 06:22
#783004
Do you have the service manuals for your bike? You'd need the KZ1000/1100 base manual and the KZ/ZX1100 GPz supplement manual.
If the primary resistance is supposed to be around 2.2 ohms, then you can probably use either the grey 2.2 ohm coils or the green 3.0 ohm coils or the Accel Super Coils mentioned by CoreyClough.
The following site has the pdf manuals. The one listed as Z1000 J 1981-3 Kawasaki Service Manual is the KZ1000/KZ1100 base manual, and the supplement manual is the one listed as GPZ 1100 1983 Kawasaki Service Manual.
zedrider.co.uk --- various service & owner's manuals plus several wiring diagrams & parts lists
The KZ1000R site has the same pdf manuals, but they are listed differently. KZRider may have them as well.
kz1000r.com.
Last edit: 07 May 2018 06:22 by JMKZHI.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 May 2018 06:24
#783006
I'd get the 3 OHM in case the ignition takes a dump. Then I could get a dyna S and not have to BUY COILS TOO. :angry:
  • man-of-war
07 May 2018 07:30
#783009
........The Dyna site mentioned to go with a replacement coil that exceeding the 1.8 ohm value of my stock. I dont want to up grade the system to a Dyna S ...Just want to do a quick coil upgrade. I'm taking it that not all 1984 GPZ 1100 Kawasaki adapt to the Dyna Coil upgrades.
  • DFIGPZ
  • DFIGPZ's Avatar
07 May 2018 15:56
#783027
If you use Grey 2.2 ohm with factory stock ignition you will be fine I have done it many times.
1984 750 Turbo
  • man-of-war
07 May 2018 16:24
#783028
Thanks , DFIGPZ I'll PLACE AN ORDER FOR THE Greys.
