Carb overflow leaking gas and petcock problems
  • apbling
  • apbling's Avatar
Re: Carb overflow leaking gas and petcock problems
30 Apr 2011 16:02
#447852
Should be pretty much the same. Just pull all the jets out run carb cleaner and compressed air through everywhere to make sure all passages are clear.
Do you have a manual? You can download it from a member here if you don't.
  • Morius
  • Morius's Avatar Topic Author
30 Apr 2011 19:34
#447880
Well, I don't have a manual of my own but, I was looking at one someone posted online. I just found the manual on this site and it's a lot easier to read and it's nice that I can download it. I think I'll have to print out the Carb rebuild section to take out to my garage.
Question: If these are not stock jets then there wouldn't be a point to buy rebuild kits w/ jets in it would there? I could get one that just has new gasket's and rings?
Thanx for the advice
John
1982 KZ550 LTD
  • apbling
  • apbling's Avatar
30 Apr 2011 22:27
#447899
Good point, a rebuild kit would have stock jets, which aren't much help to you. I'm guessing you won't need them anyway, unless yours are really really bad...
