gas tank mystery solved!
  • apbling
  • apbling's Avatar Topic Author
07 Apr 2011 11:07
#443200
So last night I was looking in my 80 750-4 LTD gas tank and saw a big piece of black crap. Turns out its the homemade gasket I made to plug my fuel sensor that was leaking. The rubber I used must not be gas resistant. At my work we have a plyable teflon gasket material I was thinking of trying. Anyone have any other advice for a good gas resistent material to make a gasket?
The reason why I dont use the sensor is it was leaking down the stem where the wires ran, plus I don't really care that much if it works or not.
The silver lining here is I thought I had a rust issue, but turns out the rust isn't too bad at all, it was the rubber plugging stuff up! :):):)
  • martin_csr
  • martin_csr's Avatar
Re: -
07 Apr 2011 11:51 - 12 Feb 2013 12:36
#443211
Maybe get a replacement fuel level sensor & install it w a new o-ring.
HarborFreight & other places sell metric nitrile o-ring kits.
Last edit: 12 Feb 2013 12:36 by martin_csr.
  • apbling
Re: gas tank mystery solved!
07 Apr 2011 12:09
#443218
I would buy those o-rings for this, but the its the really large o-ring (its oval and the size of your entire thumb, like the one on the petcock).
I haven't seen a nice sensor on ebay for a good price yet. if I come accross one, sure I'll pick it up, but at the time the bike needed to get running and prove it was somewhat reliable before I stuck too much $ into it.
  • martin_csr
Re: -
07 Apr 2011 12:13 - 12 Feb 2013 12:29
#443219
An o-ring will work. Fit the o-ring into the groove, hold it in place using both hands, lower the sensor into the hole, hold it tight against the tank w one hand, then install the bolts w the other hand. I guess it takes some dexterity, but I thought it was easy.
Last edit: 12 Feb 2013 12:29 by martin_csr.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
07 Apr 2011 15:20
#443246
Any new Nitrile, Viton(better supposedly), O-ring will work fine.
Peace.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • apbling
07 Apr 2011 16:15
#443255
OK, was digging around at work here and we have both nitrile and vitton gasket material. I was told to tell the difference is one of them "bounces" and one doesn't. So, we took a punch and kind of droped it on the rubber. I took the one that bounced because the storeroom guy thought that was the vitton one. You guys know any other way to tell the difference?
Working at a chemical plant, we got some nice goodies in the store room :)
  • H1Vindicator
  • H1Vindicator's Avatar
07 Apr 2011 18:32 - 22 Jan 2013 01:14
#443275
Last edit: 22 Jan 2013 01:14 by H1Vindicator.
  • apbling
08 Apr 2011 14:42
#443422
maybe I didn't explain it well enough, but the orgial leak wasn't around the perimeter of the sensor "mounting plate/surface" or the screws, but it was where the wires come through the plate from the sensor. There was a rubber grommet looking thing there, but it wasn't holding. So that's why I modified it.
  • H1Vindicator
08 Apr 2011 15:00 - 22 Jan 2013 01:14
#443424
  • apbling
08 Apr 2011 17:40
#443451
I agree. Just gotta find one :)
  • H1Vindicator
08 Apr 2011 17:50 - 22 Jan 2013 01:14
#443454
  • apbling
09 Apr 2011 11:58
#443636
I agree... I'm about as cheap as a SOB as you'll find.
Oxalic acid is brewin in the tank as we speak. Once the wife goes to work today, I'll go out there and finish it up.
