should i be letting carbs scare me this much?
  • MFolks
  • MFolks's Avatar
Re: should i be letting carbs scare me this much?
18 Feb 2011 22:25
#431722
Pardon me, I missed you have a 81 Kz650. another good website is www.kz650.info
  • trianglelaguna
  • trianglelaguna's Avatar
18 Feb 2011 22:47
#431723
there is a cool youtube of this two guys t.v show syncing a old school bike for their show...i'll link it when i get off work tonight....helped me to remember some stuff...yrs ago i knew how....:woohoo:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
18 Feb 2011 23:42
#431728
found this to be helpful..short but adds to the topic
kzrider.com/index.php?option=com_kunena&...ed+to+your+favorites .
watch the whole clip ,as it is helpful,and @ 7:30 or so in the clip they sync the carbs too...
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
  • martin_csr
  • martin_csr's Avatar
Re: -
19 Feb 2011 06:53 - 11 Feb 2013 13:01
#431738
Last edit: 11 Feb 2013 13:01 by martin_csr.
19 Feb 2011 09:06
#431754
ninjaracerchick wrote:
...anyone know where i can find instructions on how to sync?
First comes the BENCH sync which adjusts all throttle slides to the exact same height (as a beginning position for later "engine running" sync).
While performing the BENCH sync, it's important to have the idle thumb screw set in a position whereby the threads will permit further dropping of the slides during the later "engine running" sync where it's often necessary to reduce rpm.
Failure to have the thumb screw in proper position during bench sync may result in running out of threads needed to sufficiently reduce rpm during the "engine running" sync, in which event the bench sync must be repeated with the thumb screw in correct position.
Good Fortune! :)
  • trianglelaguna
19 Feb 2011 09:53
#431758
may need to click and enlarge to read...
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
19 Feb 2011 09:54
#431759
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
19 Feb 2011 09:54
#431760
1976 KZ900
2003 ZX12R
2007 FZ1000
