kz1000 carb boot diameter
  • notaduc
  • notaduc's Avatar Topic Author
23 Jan 2011 13:00
#424737
Hey, I dont have a sent on hand, can someone tell me the I.D. of typical MK11 kz1000 carb boots.
Thanks.
1980 (mostly) KZ1000
  • notaduc
Re: kz1000 carb boot diameter
23 Jan 2011 15:03
#424780
I was sure Id see a reply in moments here.
Just crickets.
  • Nebr_Rex
  • Nebr_Rex's Avatar
23 Jan 2011 15:29
#424787
Thanks.
1.325 in. o.d. is what I measured on the carb,or 33.65mm.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
23 Jan 2011 15:29
#424788
Thanks.
Am uncertain what is meant by carb boots. :unsure:
Sometimes it's intended as a synonym for air intake hose.
Other times it's intended as a synonym for carb holder.
Good Fortune! :)
  • Motor Head
  • Motor Head's Avatar
23 Jan 2011 15:37
#424791
  • notaduc
23 Jan 2011 15:59
#424802
Sorry, carb holders.
I need some with 38mm id where the carbs insert.
Ideas?
  • Motor Head
23 Jan 2011 16:03
#424804
Z1 has them, just look at those links, then reenter the model info. I think I guessed wrong on your model as these are smaller. But Z1 for sure should have them
  • TexasKZ
  • TexasKZ's Avatar
23 Jan 2011 16:57
#424821
Are you planning to install some larger than stock carbs? If so, here is a possibility.
kzzone.com/carbs.html
  • notaduc
23 Jan 2011 17:30
#424832
I am, the OD is 38mm. I saw the ones on kz zone, but no size listed.
There are none listed on Z1 that say 38mm, but not all of them have the size listed.
I found this old post that talks about "the old ones are 38mm" but cant figure out what the "old ones" are.
kzrider.com/index.php?option=com_kunena&...iew&catid=3&id=74225
  • Motor Head
23 Jan 2011 17:33
#424833
If you can wait till tomorrow, I would call Z1. They will have them, 90% sure.
  • PLUMMEN
  • PLUMMEN's Avatar
23 Jan 2011 17:35
#424835
ive got 4 in my sock drawer from when i took the 38s off my 1327,want em? B)
  • notaduc
23 Jan 2011 17:38
#424841
Yes please. What were they from.
