Carburetor problems
Re: Carburetor problems
12 Feb 2011 17:10 - 12 Feb 2011 17:12
#430286
Are valve clearances to spec on #4 cylinder?
Easy to measure with a thickness gauge.
Good Fortune! :)
Last edit: 12 Feb 2011 17:12 by Patton.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
12 Feb 2011 19:24
#430316
Good Fortune! :)
+1
40psi is a valve barely seating. Probly incorrect shim maintenence, or something on the valve face/seat.
Putting oil in a cylinder with bad rings makes the compression skyrocket, so if it didnt go up much, you're correct with the valves assumption, or your compression tool was no seated properly...?
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Emberblade
  • Emberblade's Avatar Topic Author
14 Feb 2011 14:56
#430663
where can I buy new air screws and jets for the carbs?
1982 KZ1000J ELR Clone
  • mjg15
  • mjg15's Avatar
14 Feb 2011 16:09
#430683
Try Z1 Enterprises for the carb parts. If they don't have them they will know where you can find them.
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
