Thinking about ditching the pods
- Frankn9
Re: Thinking about ditching the pods
11 Jan 2011 15:52
I think I'd be going up a jet, so I could put the needles back where they belong. just a thought!
- TeK9iNe
- What did you do!?!
12 Jan 2011 08:25
fordtruck wrote:
That sucks... :S With larger pilots, might just compound that issue... It can be done, its just generally frustrating and expensive!
Air box will work as it was intended, but can be fairly restrictive... inside cylinders do get hotter, and thus give leaner reading on the plug, in "most" cases. Some guys jet richer inside to prevent that - thats why with pods, jetting richer outside, most guys say it dont make sense, but it works...
you can also change to a colder plug, and run the bike with leaner settings all around, and it will be fine as well - quite peppy!
Best of luck!
Regarding the mixture screws, I tuned each one to give the highest rpm first, then tried richening each one the same amount. I could get to a point where the surging was pretty much eliminated but idle was terrible because it was so rich.
I'm going to try it with the airbox. If I lose too much power, then I will try the pods again with your method of tuning it. Funny thing is, by reading the sparkplugs it looked like the inner two cylinders were running leaner than the outer ones.
Best of luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
