new build 1075 w/29 smoothbores - idling questions
- lewisj
28 Nov 2010 14:04
Finally got the old girl(73 Z1) running after 2 years of rebuilding. Have a MTC 1075cc kit, andrews 3x cams and 29 smoothbores. The bike fired right up and settles into a high rpm @ 2000 and will then fall and die. It has a Dyna S timing on it when I move the F marker to the timing mark it dies immediately. Carb wise I have 120 Mains, 0.9 air jet, o_6 needle jet, 20 pilot and the clip is at the center position. Air screw is 1 1/2 turns out. Where would you guys start to get the idle set. I know there are a million variations and many senario's, but I could use some help getting started. Thanks in advance.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- Jeff.Saunders
Re: new build 1075 w/29 smoothbores - idling questions
28 Nov 2010 16:55 - 28 Nov 2010 16:55
Do you know what slide cutaway you have on your slides? 1,5mm or 2.0mm cutaway?
If you don't know, pull the carb top off - and using a flashlight see if 1.5 or 2.0 is stamped on the top of the slide. It makes a big difference to the pilot circuit tuning.
Typically the 2.0mm cutaway was sold for Suzuki GS models - but with parts changing hands over the years you can't rely on what you are told.
Also, have you checked/set the fuel height? 23mm is the dry setting (+/1 1mm) - measured with the carb upside down from the gasket surface (with the gasket removed) to the top of the brass float.
What petcock are you running? It's worth checking you are flowing enough fuel. Take the hose off the carbs and run into a can - when you turn on the petcock you should have a steady stream - if it starts out fast and slows - check the gas cap vent (on the underside of the gas cap and/or the petcock filter.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 28 Nov 2010 16:55 by Jeff.Saunders.
- keith1
28 Nov 2010 17:25
Jeff.Saunders wrote:
what jeff said......also make sure your cam timing is dead nuts on.....i chased down what i thought was carb problem for a long time(3 sets of carbs of diff sizes)only to discover i was a tard on the cam timing.....thing would idle at 1500 and any attempt to lower it resulted in silence.....your carb settings dont seem that far off that you cant adjust out the problem......let us know how you make out......29's with 20/120 should have you in the ball-park......
- lewisj
29 Nov 2010 06:29
Jeff, I am using a new pingle high flow with one of your inline filters. I also have your 29mm float tool so I will check the fuel float height as well.
Thanks jim
Thanks jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- lewisj
29 Nov 2010 06:31
Jeff is the 1.5 or 2.0 stamped on the inside or outside of the slide cutaway?
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- lewisj
29 Nov 2010 06:34
Thanks Keith1,
The cam timing is spot on. I had it done by a great mechanic that works exclusively on these bikes and he sold me the andrews 3x cams. He is a great source. I could probably drop the whole bike off to him, but I love working on this thing. I will keep fiddling with your suggestions,
thanks jim
thanks jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- Jeff.Saunders
29 Nov 2010 07:49
lewisj wrote:
It's stamped on the top of the slide next to where the linkage bracket attaches.
Jim
Z1 Ent on Facebook,
- Gman
29 Nov 2010 16:57
Just for giggles, try your air screws at 1/4 turn out. Some of the 29's like this setting instead of the 1 1/2 turns out. I don't know if it's the differences in the slides or something else.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
2002 Gold Wing
1974 Z1 900 project
- larrycavan
29 Nov 2010 17:38
Gman wrote:
Bingo!
Bingo!
- lewisj
30 Nov 2010 05:06
Jeff,
I checked last night and the slide cutaway is 1.5. haven't had a chance to measure float height yet.
jim
jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- lewisj
30 Nov 2010 05:08
Gman and Larry,
I figured I would have to mess with those a little. I will give it a try tonight.
Thanks Jim
Thanks Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- larrycavan
30 Nov 2010 05:13 - 30 Nov 2010 05:17
lewisj wrote:
Close them all up, then back them out 1/4 turn. I've never seen a rack of 29's that didn't work with 1/4 - 3/4 as the final setting. Idle circuits on those carburetors are not very refined. Air screws can sometimes be all over the place. Don't think for one second they all have to be the same setting because often, they're not.
3x cams have a lot of overlap lift. That in itself leads to a weak signal at the carburetor at low RPM. Also they would on occasion spit shims. I wouldn't run them with S.O.T. buckets myself but there are those who would argue that...
Gman and Larry,
Thanks Jim
Last edit: 30 Nov 2010 05:17 by larrycavan.
