Mikuni 29mm Jet Block
- BIGKEVIN
10 Nov 2010 16:43
I stripped the jet block in my Mikuni 29mm carbs. Does anyone have one that they are willing to get rid of ?
1976 KZ900
2006 ZX6R
2006 ZX6R
- andy9802gt
- If it tastes that good, eat it yourself.
Re: Mikuni 29mm Jet Block
10 Nov 2010 16:58
If I remember correctly Redline can get a replacement made for you.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- DFIGPZ
- BIGKEVIN
10 Nov 2010 17:22
Does anyone know if the jet block from a different size carb is the same as the 29mm ?
1976 KZ900
2006 ZX6R
2006 ZX6R
- z1kzonly
10 Nov 2010 19:06
I am assuming, the main jet tube in the center? Of the body?
- kawsakiman
10 Nov 2010 20:58
BIGKEVIN wrote:
only 29's have a seperate jet block.
that is part of what makes them smoothbores.
come on guys, someone help this guy out.
( maybe a photo of your bike and face for us to chop to hell would help. :evil: )
- BIGKEVIN
11 Nov 2010 13:37
I can get a replacement jet block from redline like any9802gt said, but I cant get the rod out of the carbs to get them separated. Can someone help me again ?
1976 KZ900
2006 ZX6R
2006 ZX6R
- moneypit
11 Nov 2010 13:42
Mybe I should start making these. LOL
www.motorcyclecarbs.com/_P10876.cfm
2-76 kz900
St Paul MN
St Paul MN
- moneypit
11 Nov 2010 13:44
Heres an exploded view
www.motorcyclecarbs.com/Mikuni_VM29_Smoo..._Parts_W310C1669.cfm
2-76 kz900
St Paul MN
St Paul MN
- BIGKEVIN
11 Nov 2010 14:34
I can get to everything, but I havent been able to figure out how to get the rod out that runs through all 4 carbs.
1976 KZ900
2006 ZX6R
2006 ZX6R
- moneypit
11 Nov 2010 14:47
That rod goes through all of the slide linkages each has a screw. also part number 54 holds that rod from moving side to side, held on by #53 then it slides out. Its been awhile since I did mine so I might not be thinking of everything
Good luck
Good luck
2-76 kz900
St Paul MN
St Paul MN
- BIGKEVIN
11 Nov 2010 15:43
My carbs do not have part #54. On one side of the rod there is a slot for lining up a metal piece to get the rod to move, but I have not been able to figure out how to move it. Does the spring inside the top cover need to come off ?
1976 KZ900
2006 ZX6R
2006 ZX6R
