doesn't want to idle down after warming up???
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
Re: doesn't want to idle down after warming up???
07 Nov 2010 09:44
#411474
That Patton, he's quicker than me!
07 Nov 2010 09:57 - 07 Nov 2010 09:59
#411481
BIGKEVIN wrote:
How do you check the ignition advance mech ? I am having the same problem on my 76 KZ900.
Here's a pic (underneath the points cover).
Good Fortune! :)
[Click on image to enlarge view.]
Last edit: 07 Nov 2010 09:59 by Patton.
07 Nov 2010 10:02
#411482
:laugh: :laugh: :laugh:
  • seanbarney41
07 Nov 2010 10:17
#411490
Yeah Bigkevin, it turns out Vernons prob was cured by resetting a tight point gap so after your done be sure and check your point gap and timing!
07 Nov 2010 10:25 - 07 Nov 2010 16:11
#411492
Would concur with seanbarney41 about checking point gap and timing.
Remember to first clean contacts, and then set the gaps, both before adjusting the ignition timing.
Here's a pic that may be helpful.
Good Fortune! :)
Last edit: 07 Nov 2010 16:11 by Patton.
  • seanbarney41
07 Nov 2010 14:34
#411522
Yeah, that's what I meant.
07 Nov 2010 16:28
#411535
Where contacts are pitted, it's sometimes easy to smooth their mating surfaces by using a strip of very fine sandpaper, folded so there's grit on both sides of the strip.
Then place the strip between closed contacts, and pull it back and forth, to simultaneously dress both contacts. If additional pressure is desired, just use your fingers to press the contacts slightly tighter together while pulling the strip back and forth.
It shouldn't require many pulls.
A standard "points file" may be used instead of the sandpaper strip, but chances are that the sandpaper method will be deemed preferable.
Next --- Spray some contact cleaner (or similar non-residue electrical cleaner) on the contacts.
Use a thickness (feeler) gauge to adjust the gap.
Then repeat application of contact cleaner.
The contacts should now be smooth, mating evenly, with proper gap, and perfectly clean.
Proceed with ignition timing.
Good Fortune! :)
  • BIGKEVIN
  • BIGKEVIN's Avatar
09 Nov 2010 14:01
#411880
I tried to adjust the points on my 76 KZ900 for the first time. Am I supposed to see sparks across the points when trying to start the bike ?
1976 KZ900
2006 ZX6R
