82 KZ 750N1 Spectre
- xmoney
82 KZ 750N1 Spectre
03 Oct 2010 06:22
Hello, I am new to the forum. I have a 82 KZ750N1 and, I am trying to adapt a set of 900 eliminator carbs to it. and I am having some issues:dry: with the intake spacings. Can this be done? The orig. set of carbs for this bike are not salvageable. I am having difficulty finding the correct carbs. Does any one know if this conversion will work? Thanks, Jeff
1992 Harley Davidson FXDC Full Custom
1982 KZ 750 N1 Cafe project
1970 BSA Thunderbolt OIF W/ Lightning twin carb Head Bobber/ Cafe Stayle (Project )
- xmoney
Re: 82 KZ 750N1 Spectre
03 Oct 2010 06:51 - 05 Oct 2010 15:45
Last edit: 05 Oct 2010 15:45 by xmoney.
- xmoney
05 Oct 2010 15:49 - 05 Oct 2010 15:52
Last edit: 05 Oct 2010 15:52 by xmoney. Reason: no picture showed up
- otakar
05 Oct 2010 16:08
Post a few pictures of the carbs you are trying to mount and it will be simpler for us to answer you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
05 Oct 2010 16:16
Looking at Kawasaki.com, the Eliminator carbs will not work without MAJOR modifications. You require carburetors for ANY of the AIR COOLED 750s. You would be best off with carbs for the GPz 750s because they are Mikunis and not Keihins. Parts are much simpler to find for Mikuni carbs than they are for Keihin carbs. I am not sure why your carbs can not be rebuilt unless they are smashed up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- dejavoodo41
05 Oct 2010 16:19
no thoughts on the carb issue but I like you scoot!
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- otakar
05 Oct 2010 16:21
Doing more research on your carbs (OE) they are the duel butterfly Keihins and were always a pain in the ass. Find a set of Mikuni carbs for a GPz750. they are available on eBay all the time and are not bad to rebuild and the parts are mostly available.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
05 Oct 2010 16:24 - 05 Oct 2010 16:28
No eBay APP ID and/or Cert ID defined in Kunena configurationHere seams to be a good set. I would bid as high as $150 for them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 05 Oct 2010 16:28 by otakar.
- xmoney
05 Oct 2010 18:37
Thanks Guys ! I appreciate all the great responses. I do have them mounted for now. I solved the problems of the spacing with some mods between the 2 pairs. I will get some more photos posted of the carb assy once I pull it back off the engine. I am looking at the Gpz carb assy's now. What major mods need to be done other than jetting if I decide to run the Eliminator carbs?
- xmoney
05 Oct 2010 18:43
Thanks! I will get some more shots posted. It now has the rear sets all mocked up and, the small fairing mocked up. i have a new set of Buell gauges I am going to install soon . That ought to be a lot of fun! I like that bike of yours! I need to find a 1000 and start yet another project. Jeff
- otakar
05 Oct 2010 18:44
xmoney wrote:
??????? never attempted those. They are set up for a higher RPM engine therefore most likely completely different.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- xmoney
05 Oct 2010 18:45
I will get some this week. Thanks for the help. That is a nice set !
