Ultrasonic carb cleaning
  • testarossa
  • testarossa's Avatar Topic Author
30 Apr 2010 22:26
#364621
I have been testing different methods of cleaning carburetors for rebuilding. So far I have tried Berrymans Chemtool, mineral spirits, soda blasting, aerosole carb cleaner, and finally ultrasonic cleaning. I relly like the ultrasonic cleaner for alot of reasons. It's effective, no harsh chemicals, and its relatively fast. Here's a couple of videos of my little ultrasonic in action.
s915.photobucket.com/albums/ac360/jtshar...rent=Ultrasonic1.flv
[IMG
Notice the plumes of gunk forming around the part. Keep your volume down!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Galactica
  • Galactica's Avatar
Re: Ultrasonic carb cleaning
30 Apr 2010 22:43
#364623
You say relatively quickly. How long is that? Could your unit work on a head or cylinder unit? Did you make your sonic cleaner yourself, and how did you do it?
77KZ1000
76 KZ900
  • testarossa
30 Apr 2010 23:10
#364629
The cleaning action is quite effective within 15 minutes. My particular unit would not work for a head or cylinder block based only on the size. If you had a large enough tank, then you could clean just about anything. I will say that you wouldn't want to purchase a larger unit as an individual hobbiest. The larger units easly get into the $10,000 range. I didn't make my own cleaner. It is a Branson 1200 which is a small older unit that is about $200 IIRC. I was lucky enough to get this one as a freebie. My father worked in the maintence department at the production facility for James Avery Jewlers for the last 5 years of his working life. They would periodically replace these pieces of equipment and donate the used pieces to employees. Dad had no use for this, so I lucked out.
I bet that some of the more electrical savvy members could work out a way of building a similar unit. It appears to be a small piezo-electric? unit glued to the bottom of a stainless tub, that is controlled by some fairly simple electronics. Quite remarkable actually. My unit is very bare-bones. No heater or timer or frequecy control, but after about 15 minutes, it will turn room temp. water into bathwater (100F) due to the vibrations. Hope this helps.
2004 ZX-10R
Angola, IN
  • Galactica
01 May 2010 09:52
#364698
Very interesting unit.
77KZ1000
76 KZ900
  • keith1
  • keith1's Avatar
  • Away
01 May 2010 19:25
#364836
x2.....can you post up pics of the cleaner?
  • Tony
  • Tony's Avatar
    Author
01 May 2010 21:03 - 01 May 2010 21:04
#364871
I know this isn't as high tech, but what I have done in the past is tape a container with parts and cleaning solution to the motor part of a bench grinder, turn it on and have a makeshift ultra sonic cleaner. It worked pretty good as opposed to just letting the parts soak.
Last edit: 01 May 2010 21:04 by Tony.
  • keith1
  • keith1's Avatar
  • Away
01 May 2010 21:08
#364873
now THATS using your head for more than a hat rack.....excellent idea.....
  • Tony
  • Tony's Avatar
    Author
01 May 2010 21:19
#364875
I've used ultrasonic cleaners before and they are great, but pricey. So we make do with what we have...
How do that saying go? "Necessity is the mother of invention."
  • testarossa
01 May 2010 21:21
#364877
Here's a link to their website.
www.bransonic.com/
The model that I have is older and discontinued. The closest thing that they have now is the model 1510. I think that it retails for about $350.
I'll get some pics tomorrow. My camera phone doesn't like artifical light, and the picture right now would be poo.
2004 ZX-10R
Angola, IN
  • testarossa
01 May 2010 21:24
#364878
Really good idea Tony. The constant agitation helps alot. The ultrasonic is just agitation on an epic level. However, at the frequencies that the ultrasonic operates, there is alot more going on than simple agitation.
2004 ZX-10R
Angola, IN
  • Tony
  • Tony's Avatar
    Author
01 May 2010 21:55
#364889
Agreed. It's more an alternative to just soaking.
  • testarossa
02 May 2010 15:56 - 02 May 2010 15:58
#365048
As promised, here is a pic of my little ultrasonic cleaner next to something that you should be familiar with for scale.
2004 ZX-10R
Angola, IN
Last edit: 02 May 2010 15:58 by testarossa.
