different kz1000j carburetors***???
- kawastrtfgtr
19 Nov 2009 01:51
hi, anyone what kind or carburetors ı can install my kz1000j engine, original is mikuni bs34, and lots of near same carburetors on japanese motorcycle as gs1000,xs1100 fit it u dont make change any thing ı guess.
is it posible to fit (gsxr-fzr-zxr-zzr-zrx-cbr-cb-fz-fj-ninja-or what else) carburetors?
ı just want to screw bolts. does anybody know about these type japanese carbs ı can fit j engine without make any changes?
- otakar
Re: different kz1000j carburetors***???
19 Nov 2009 03:52 - 19 Nov 2009 05:30
The spacing is different on all of those carbs. The KZ/ZN/Z 900/1000/1100 carbs from 1973-1985 interchange only. Why would you want to change. The BS34s are an excellent carburetor. I run them on my highly modified bike. You can find the complete description in the 1100 Gallery pictures.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Nov 2009 05:30 by otakar.
- otakar
19 Nov 2009 05:31
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kawastrtfgtr
19 Nov 2009 06:27
because mine carbs not well, my bike runs on choke only,1# cylinder doesn't run now.it coughts and fire go out exhaust.ı cleaned them twice and carbs aren't go well.now ı'm looking carbs,yeah bs34 was fine.
- otakar
19 Nov 2009 06:39
I would fix them or find another set of BS34s for a KZ1000/1100 on eBay. What country are you in?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kawastrtfgtr
19 Nov 2009 23:14
ı m from Turkey, now ı m looking for it but shipping here is expensive.
- otakar
20 Nov 2009 03:05
Than, I would completely rebuild the ones you have.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kawastrtfgtr
Re: spark plugs
12 Jan 2010 12:26
there are two types of ngk br8es spark plugs, one is 0.18mm, the other is 0.35mm, whis is best for kz1000j engine?
- otakar
Re: spark plugs
12 Jan 2010 15:59
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: spark plugs
12 Jan 2010 16:01
But I do not care for NGK plugs. I much better like the Denso W24ES-U they are also an inexpensive Japanese plug.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
Re: spark plugs
12 Jan 2010 16:02
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
Re: spark plugs
12 Jan 2010 16:40
if your carbs are only running on the enrichener then you still have plugged pilot jets those carbs will have to come apart again. there are many different styles of carb you could run on your bike vm33 mikunis, rs 34or 36 mikuni flat slides or keihin 33 or 35mm cr's all these carb are available from the aftermarket my self unless you have done a lot of hot rod work (higher compression, bigger bore , head work, and big cams) i would probably stick with the stock carbs and just clean them properly.
I THINK MY POWERBAND BROKE
