Ahhh found a crack! What would you do?
  • 550A2
  • 550A2's Avatar Topic Author
  • keep the shiny side up
12 Aug 2009 15:57
#313438
Well, ive been wonderin for a while why my bike idles rough....ive checked the carbs and vaccum hoses for any leaks and found none which is good.
it still ran like it had a vaccum leak, but none turned up. Then today i thought to look at the boots from the head to the carbs.
Sure egnough, there is a crack in cyl #4 boot. I sprayed some carb cleaner on it when it was running and it started choking.
Im glad i found it! ;)
But does anyone have any suggetions on a quick fix until i can score some new boots???
thanks
Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • 550A2
Re: Ahhh found a crack! What would you do?
12 Aug 2009 16:02
#313439
and where to get some new boots, Z1 aint got none.
  • mzandmz
  • mzandmz's Avatar
12 Aug 2009 16:03 - 12 Aug 2009 16:04
#313440
I wonder if silicon or that glue they use to fix inner tube patches?Kinda like rubber cement. You need something pliable that can move with the rubber.What Bike do you have?
New to Family, 1979 KZ440 LTD
Last edit: 12 Aug 2009 16:04 by mzandmz.
  • mzandmz
  • mzandmz's Avatar
12 Aug 2009 17:14
#313458
powersedge.com has them.
  • Royal1MC
  • Royal1MC's Avatar
  • Is it just me, or is it just great to be on a KZ
12 Aug 2009 17:25
#313460
The boots are still available through the Kawasaki Dealer.
Part # 16065-1014 is showing active under Item Status Code.
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
  • 550A2
12 Aug 2009 18:17
#313467
Alright thanks alot guys, i think its just black rtv silicon.
I have an 82 kz550 a2.
i put some on so hopefully it runs a little better in the mornin.
Ill check these babys out though, see what kind of deals i prices i can get.
Thanks again.
  • TerryK
  • TerryK's Avatar
12 Aug 2009 18:27
#313472
Gasoline will eat the silicone pretty quickly. Buy the new flanges and be safe and happy.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • trianglelaguna
  • trianglelaguna's Avatar
12 Aug 2009 18:43
#313483
crack....shit.....i smokes cracks.....
does z-1 enterprises.com sell em for your model they are great on price and ship super fast for like ten bucks and will sell you the right one the first time......i dig getting stuff from em.....p.s there carb clamps are gun metal black and are a great deal too...new screws.....woohoo it's fun to spend money....but seriously you got some extra cracks?????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • 550A2
12 Aug 2009 18:56
#313489
Yeah, i found them!
There 86 bucks though....fak! kinda pricey for rubber flanges.
ill have to get them though, then get a sync.....
that should do the trick.
ehhhh, no crack smokin here, just crack sealin.
lol
dave chappele is the shit.
  • TerryK
  • TerryK's Avatar
12 Aug 2009 18:58
#313490
550A2 wrote:
Yeah, i found them!
lol
You think that's pricy? Check the OEM Kawasaki ones. It'll scare you into buying the aftermarket ones.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • mkeating
  • mkeating's Avatar
13 Aug 2009 06:47
#313577
Hey there,
I also have some cracks in my boots and I plan on using gorilla glue or elmers ultimate glue to bond the inside of the crack together. From there I am simply going to use some plastidip and apply a very thin coat over the crack with a small brush. Many people have used this for diaphragm repair, but I have also heard of it being used for carb boots as well. I am not sure where you are from, in the states you can get plastidip at Napa and Home Depot. In Canada I found some at Home Hardware. You can check their site at plastidip.com. Also for past stories on the use of this stuff check :
www.kawasakimotorcycle.org/forum/vintage...gm-repair-works.html
or this link talks about using it for carb boots:
www.xs11.com/forum/showthread.php?p=2972
Let me know how you make out. I will be doing mine this weekend!
  • Ironhorse
  • Ironhorse's Avatar
  • www.ridelikeaprowestcoast.com
13 Aug 2009 07:10
#313581
On a couple of my KZ1000s I have found the cracks to be surface and not breaking all the way through (although they WILL eventually). Most of the leaking came from the bolts loosening up and causing the leaks. So I tightened them down until I picked up new ones.
Real learning begins after you know everything.
