AnyOne have easy float level Check?
  • mzandmz
  • mzandmz's Avatar Topic Author
10 Aug 2009 23:39
#313067
Any good Ideas on how to check float level on stock 77 KZ650 carbs? Quick way. or Correct way? 2-3 mm from mating surface? Clear tube somehow attatched to the drain holes.?
Start by making sure the pet-cock is closed. Drain bowl and hook up clear hose ??? and hold up by the carb turn back on pet-cock and wait till fuel stops filling in the tube, measure level to the mating surface around 2-3 mm???? Check the other three the same way with the bike on center stand????? What do I use for a connection from bowl to tube??????
New to Family, 1979 KZ440 LTD
  • Bluemeanie
  • Bluemeanie's Avatar
Re: AnyOne have easy float level Check?
11 Aug 2009 06:16
#313094
You pretty much have every thing correct but here is the connection you need. I'm gonna get me one!
  • bill_wilcox100
  • bill_wilcox100's Avatar
11 Aug 2009 06:33 - 11 Aug 2009 06:36
#313098
Hi mzandmz, this is the higher cost alternative.
This is where I got mine Link
Best of success. :)
Bill
PS
Don't forget to add your year, model and location to get the best responses... and it's considered real friendly too.
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 11 Aug 2009 06:36 by bill_wilcox100.
  • JMKZHI
  • JMKZHI's Avatar
11 Aug 2009 06:38
#313099
Others have reported using a plastic vacuum fitting from the auto parts store. They just screw it into the drain screw hole, cutting new threads on it. Any leakage would probably be minimal or insignificant. Or put teflon tape on the threads.
  • mzandmz
11 Aug 2009 07:54
#313111
Thanks for picture and location of where to find tool.
11 Aug 2009 08:23
#313116
The end of a proper size (outer diameter) soft plastic hose will itself "thread" into the drain screw hole. Without needing anything else. No device, no barb, no nothing.
Is quick and easy, and with minimal or irrevelant leaksge.
Perhaps a good hardware store or hobby shop.
Good Luck! :)
  • mzandmz
11 Aug 2009 08:38
#313118
Do you check all four at the same time????If you want to
11 Aug 2009 09:05
#313124
I just check one at the time. Because of needing to hold the plastic hose so very still and steady against side of the floatbowl during the "filling and reading" part of the test.
Besides, I only have one hose. :lol:
Good Luck! :)
  • mzandmz
11 Aug 2009 09:15
#313126
Thanks,I guess it doesn't matter,it sounds painful any way you do it. Drain,tube,fill,drain,adjust bla bla bla on to the next three......
11 Aug 2009 09:40 - 11 Aug 2009 16:27
#313133
"Checking" is relatively painless, compared to "adjusting."
If done with carbs on the bike, I perform the test outside on the driveway, with a shop towel under the carbs to catch and soak up any gas spillage.
"Adjusting" is for me a carbs-removed-and-on-the-bench procedure. And testing each successive float tang adjustment with carbs on the bench.
Only need one floatbowl screw during testing.
And even this float tang adjustment procedure is best done on an outside table, imo, with carbs preferably "downwind."
Once set correctly with proper tang adjustments, the levels should remain good-to-go, indefinitly. As there's nothing to interfere with the adjustment following re-assembly.
Good Luck! :)
Last edit: 11 Aug 2009 16:27 by Patton.
  • mzandmz
11 Aug 2009 09:50
#313136
The guy I bought if from Had rebuilt the carbs and told me they need sync.But I dont know if he properly adjusted the float levels. Time will tell,that is when I check them out.
11 Aug 2009 10:11 - 11 Aug 2009 16:46
#313140
Would concur with verifying fuel levels before synching or other carb adjusting.
An otherwise perfect carb will suffer from incorrect fuel level. Too high = too rich. Too low = too lean.
Hopefully, the rebuild was competantly done and also included correct float heights (easily verifed with carbs on the bike by using the clear tube test).
With a good sync being the final touch. :cheer:
But wondering why anybody would rebuild carbs and not sync them. :huh:
They all say that. :laugh:
Good Luck! :)
Last edit: 11 Aug 2009 16:46 by Patton.
