DynoJet install, Drilling out the Slider?
- Johnny Red
- 80 KZ750 H LTD
12 May 2009 14:09 - 12 May 2009 14:12
I have a 81 KZ750 LTD, Im installing the Dynojet Stage 3 kit.
The kit says to drill out the side hole, but there is two side holes. Photo attached.
Do I drill out both or just one?
Last edit: 12 May 2009 14:12 by Johnny Red.
- otakar
Re: DynoJet install, Drilling out the Slider?
12 May 2009 14:14
With a marker- show the exact front of the slide (engine side)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
12 May 2009 14:16
Did you get 2 needles or four needles with your kit?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Johnny Red
- 80 KZ750 H LTD
- Johnny Red
- 80 KZ750 H LTD
- otakar
12 May 2009 14:26
looking at the picture, it looks like that someone has already drilled the second hole. This is the hole on the right as you are looking at the picture. I would be willing to bet that hole is EXACTLY at the SIDE of the RIGHT side of the slide as it goes into the carb, and the carb faces forward
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
12 May 2009 14:28
Now take a picture of the TOP OF THE DIAPHRAGM DOME. looking down the slide hole.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Johnny Red
- 80 KZ750 H LTD
12 May 2009 14:29
all four slides have two holes. I drilled out the right hand side about 15 minutes ago and was starting to drill the left side and stoped to post this topic. so the right is drilled and the left is half way drilled, but not all the way through.
- otakar
12 May 2009 14:31
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Johnny Red
- 80 KZ750 H LTD
- otakar
12 May 2009 14:39 - 12 May 2009 14:40
Do you see that GREEN Mark? That is the Diaphragm locating notch. I need to see where it is on the carburetor and on the diaphragm itself.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 12 May 2009 14:40 by otakar.
- Johnny Red
- 80 KZ750 H LTD
