a little lost
- zim6000
a little lost
30 Oct 2008 16:27
I just got my kz750 out of the shop. The carb was rebuilt
now it starts and idles well. but I had the stock air box
removed and pod filters put on and now it has no power at all.
This is where I'm lost. I don't know how to ajust the carb to get it back to where it was. I'm thinking it has something to do with the air mixter screws on top of the carbs.
I don't want to screw anything up. Any pointers would be cool.
- JohNLA
Re: a little lost
30 Oct 2008 16:50
It probably needs larger jets. Is the power loss throughout the powerband or in the low or high revs?
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
- timebomb33
Re: a little lost
30 Oct 2008 17:24
get your self a dyno-jet kit they still have them available for your bikewhen you remove the air box and install pod's it completely changes the amount air of that is available to your motor. try going bak to abase line setting with your carbs fuel screws stock thety will be 1 1/2 to 1 3/4 turns out from bottom i'd try 2 1/2 turns out to see if it is better remember to give an engine what it want's.
I THINK MY POWERBAND BROKE
- JR
Re: a little lost
30 Oct 2008 18:02 - 30 Oct 2008 18:04
Quote
"I just got my kz750 out of the shop. The carb was rebuilt"
What year ? and is it the 2 cylinder or a 4 cylinder model ?. and if 4 cylinder and 4 carbs then are the carbs Keihin or Mikuni's ?
What about the exhaust system ? Original or modified ?
Last edit: 30 Oct 2008 18:04 by JR.
- zim6000
Re: a little lost
30 Oct 2008 18:35 - 30 Oct 2008 18:37
83 I think, inline 4,Keihin carbs, original pipes .
the power loss is through the whole band.I don't know where the fuel screws are.
Last edit: 30 Oct 2008 18:37 by zim6000.
- davel
Re: a little lost
30 Oct 2008 19:09
zim6000 wrote:
Carburettor tuning is an acquired skill. If you want to learn about carburetors, buy a jet kit and plan to spend several days taking your carbs on and off and fiddling with fine adjustments in the hope of getting the bike to run the way it did before you removed the air box.
my 2 cents
I hate to say it and I know some will disagree with me but...put the air box back on. It will run perfectly and you can enjoy your bike. Even if you get the jetting right with the pods you won't get much of an increase in performance if you retain the stock exhaust.83 I think, inline 4,Keihin carbs, original pipes .
my 2 cents
- zim6000
Re: a little lost
30 Oct 2008 19:26
thats what I wanted to try but 2 of the 4 rubber connectors
that go from the box to the carb shrunk and won't fit back on. so now it looks like my options are buy a jet kit or order new rubber thingys :S
- davel
Re: a little lost
30 Oct 2008 19:37
zim6000 wrote:
Just so you know. I have an 82 GS1100E that is bone stock and runs like a bat out of hell at all RPMs. (it will give my heavily modified KZ1075 a run for its money) I've tried to run the GS before with the airbox removed and I can't even rev up the engine in neutral.
Are you sure they shrunk? How did they shrink? Usually they will get a little dry and hard with age. This will make them a difficult to fit over the carburettor mouth. If this is the case, spray them with a little WD40. It will help alot. If they're too far gone, call Jeff at Z1.thats what I wanted to try but 2 of the 4 rubber connectors
- JMKZHI
Last edit: 04 Dec 2008 09:41 by JMKZHI.
- MFolks
Re: a little lost
30 Oct 2008 20:33
If the inlet ducts/rubber tubes have shrunk try some just below boiling hot water. This will soften up the ducting and allow re-installation. Another trick is to use rubbing alcohol as a lubricant fitting the ducts to the carbs or airbox fittings.
- TODDSTER
- Die Hard & Live Free
Re: a little lost
30 Oct 2008 23:14
Laugh, but I used hair spray on a set way back when. Just like when ya change grips. Just don,'t take too long or ya hav ta spray em again.
KZ 78 650 SR D1a W/78 Quick silver 3/4 stock fairing, new dunlop rubber frnt. & back, new jcw rear shocks, new progressive frt. fork springs & 1 ground-hog to my credit.(ouch)
TODDSTER in N.Western PA
Kawi Strong w/windshield in my face
