4 in 1 or 4 in 2 exhaust
- Bluemeanie
Re: 4 in 1 or 4 in 2 exhaust
03 Dec 2006 07:40
Basically on a 4-1 system, as one pipe expels exhaust into the collector it creats a vacuum on the next pipe which helps draw the exhaust out faster. Which creats a vacuum on the next pipe, etc. Pretty simple and effective design. 4-2 systems will give slightly better bottom, midrange where as 4-1 give better mid to top end. I just love the look and sound of my old Kerker
- CoreyClough
- GPz550 Addiction
03 Dec 2006 09:19
Jeff touched on the collector issue. I have two pictures here from both a Vance & Hines, and a Super-Trapp header collector. I'm using the later of the two.
Vance & Hines Collector
Super-Trapp Collector
You want a "merged" collector for best flow, but ground clearance in corners under our bikes is probably the limiting factor for why most are like the pictures above. Cleaning up the welds a little would improve the flow, and seeing on how mine's off right now, I'll be looking into that area. Will I notice the difference? Nope, but it's something I want to do.
'85 GPz550(ZX550-A2)
- larrycavan
03 Dec 2006 16:23
I don't know how many of you noticed it, but there's a trend in the car world toward smaller, higher velocity header pipes.
The higher the state of tune of the engine, the more important pipe tuning becomes.
- wireman
03 Dec 2006 17:05
larrycavan wrote:
yep;)I don't know how many of you noticed it, but there's a trend in the car world toward smaller, higher velocity header pipes.
- kyradawg
03 Dec 2006 17:14
larrycavan wrote:
Larry I need some exhaust/intake port modeling.
Peace&Love:blink: , Darren
- larrycavan
04 Dec 2006 00:05
kyradawg wrote:
As in a port mold?
larrycavan wrote:I don't know how many of you noticed it, but there's a trend in the car world toward smaller, higher velocity header pipes.
As in a port mold?
- KZReeder
04 Dec 2006 15:21
dutchz wrote:
Those are nice looking pipes... I was running a MAC 4-1 that I really worked hard on tuning the bike to... then just for kicks one day, I cut off the stock pipes right in front of the baffle, bolted them on and was suprised at how much the power seemed to be spread out... the power was a lot broader and I liked the look a little better for my cafe project.
Got a set of 4-2 hooker pipes with a crossover on mine, similar to the milkman's Jardine but the headers cross differently. Great mid range, looks good and sounds even better...
- dutchz
05 Dec 2006 11:39
They work very well. I've put in the baffles from the old set that came on the bike, the straight-thru tubes are a little larger diameter than the ones on the NOS set I found. No packing tho :whistle:
These pipes sound bitchin... completely different from a 4-1
1974 Kawasaki Z1
Stock front hub and rear axle.
- 77KZ650
06 Dec 2006 07:15
a bit of a side note here, how does running a 4-1 without the megaphone at all compare to running the same 4-1 with the megaphone with no baffle? both are wide open, but one is longer and has the funnel shape....
Scott
Scott
07 MDP Rookie of the Year
- The Milkman
06 Dec 2006 07:38
Seems to me that having the megaphone on would create a bit more of a vaccum on the other pipes creating a better scavenging affect, and being a megaphone wouldn't it make it a little louder?
Just my thoughts.
Les
Just my thoughts.
Les
- 77KZ650
06 Dec 2006 07:58
if the megephone started back a ways from the collector would it still make extra vaccum or just if it started right at the collector?
- martijn
08 Dec 2006 11:56
This is getting very interesting!! I did have a home build 4 into one with a header of approx 20 cm long and diameter of 10cm. No bafle and big diameter pipes. It pulled very hard on a standard KZ900 from 8000 to 10.000 but it was very loud and fuel consumption was poor. I replaced it for an original one, gave more low and mid and no hard pulling engine above 9000rpm. Now I do have a shitty marshall, stock diameter pipes and very restrictive above 7000rpm. I do have the same damper on my kz650... I can't get it tuned propely with pods.
Anyway I was making plans to use the stock pipes making a two into two system. So first qeustion. Do you have to pair 1-4 and 2-3?? easier is 1-2 and 3-4 or do you get a harley effect 0 and 180 degrees fire...
I would make an oval header with the surface of the 2 incoming pipes. Headerlenght approx 20cm going fluently in a megaphone/trumpet minimal damped muffler, what do you think (especially Larry?)
Martijn
Martijn
