Thanks for all the responses, folks!
Patton wrote:
Any crud or other foreign material inside the fuel tank clogging the petcock filter? You probably already checked this, but just a thought. Was riding a new bike with freshly painted tank that would run fine for maybe a mile, then "run out of gas" -- crank back up, run fine again for maybe a mile, then "run out of gas" again.
Could be. Perhaps I have some deposits, but not enough to be affecting it at city speeds. I'll open that and check it out.
Popeye wrote:
make sure the vacuum line to the fuel cock is not cracked or squashed as well......
Checked that, it's fine. Also I ran it with the petcock on prime, so the vacuum line doesn't affect the fuel flow.
ltdrider wrote:
When's the last time you checked your valve clearances?
Probably 15k miles ago, when it was still in cop service. I haven't done this myself since then. Could this cause the problem I describe?
larrycavan wrote:
How do you know it drops to 3, then 2 cylinders?
Good question.
I don't. It just feels that way. It starts sounding different, more ragged, and I have to open the throttle much more to get the same speed. Then I slow down for a while; and after a bit, the engine operates normally again, and I can get back to normal high speed behavior for another 5 minutes.
So it seems to me that one of the floats goes dry first, quickly followed by another, then another after that....unless I let off the throttle for a bit and let the floats fill back up.
Are there other possible explanations?
larrycavan wrote:
It may be a fuel cap venting problem?
That's what I thought too. But as I said above, I tried riding the freeway with the cap propped open. Still did the same thing.
larrycavan wrote:
fuel vents, airbox, air filter, pinched hoses.
Checked all that, looks fine. I have pod filters, not an airbox--the pods are only 2 months old.
