clutch slipping - should I go with regular or race replacement?
  • Trav
  • Trav's Avatar Topic Author
26 Jul 2006 15:42
#64949
I'm pretty sure my clutch is slippin. I had always suspected it, but now since I have the 615 kit installed, I really think it is. The bike is fast and accelerates well with controlled application of throttle, but if I'm going near WFO and it gets into the powerband, it gets louder and gets to redline faster, but the bike doesn't really move faster.
I searched for "slipping clutch" and saw a thread where a guy was reccomended to get a stock replacement vs the "street racer" setup EBC has. I guess maybe that still applies here?
The bike isn't a race bike, but it isn't exactly stock either, and I feel tempted to put in the 'best' stuff because it really isn't much of a price difference. However, I don't want it unstreetable or more annoying than it is beneficial. I am the type of person who would try a burnout and picking the front wheel up here and there, though..
Here is what denniskirk has to offer:
clutch plate selection at Dennis Kirk
Post edited by: steell, at: 2006/07/26 19:48
  • 77KZ650
  • 77KZ650's Avatar
Re: clutch slipping - should I go with regular or race replacement?
26 Jul 2006 15:52
#64952
first adjust your cable to see if thats the problem, if it doesnt help, take the clutch apart and mic the parts to see if some/all are out of spec, if so, and if you have strong hands like me, go with an APE "extra plate" clutch kit with heavy duty springs. they will take abuse(aka "fun" :evil: )
that is if they make them, im not sure now that i think about it, i think just the middle weights and big bikes, if they dont make em, and your friction plates are ok, see if the aftermarket springs will swap in
Post edited by: 77KZ650, at: 2006/07/26 18:55
07 MDP Rookie of the Year
  • wireman
  • wireman's Avatar
26 Jul 2006 16:36
#64970
use the aftermarket plates with stock style springs,your left arm will thank you!:whistle: :P
  • KZDon
  • KZDon's Avatar
26 Jul 2006 19:40
#65028
Try following through the troubleshooting section in the manual for clutch slippage before you spend any dough. You might find half an hour of adjusting will save you beer money.
Midland, Ontario, Great White North
2004 650 V-Strom
farewell to 81 KZ550A2 - 82 GS750T - 83 GPz750 - R-Reg GT380 - 76 DT175 - 84 GPz550
  • loudhvx
  • loudhvx's Avatar
26 Jul 2006 22:58
#65072
Done that. Yeah, it was easier on the left arm, but it slipped like crazy at highway speeds. I put in brand new stock springs too. It would only grab fully with the recommended aftermarket springs, and they were a BITCH on the left arm!
I called three different speed shops, and they confirmed the same thing. They each said almost the exact same thing "get the stock clutch, everything else is a waste of money". So I sprung for a stock set of disks and even used my old stock springs. The bike shifted so nicely with no slippage that all the money and time I wasted on the "performance" clutch didn't even bother me.
I have yet to feel a nicer, smoother, lighter clutch among all of my friends' bikes (although my buddy's KZ400 comes very close!).
This was on a 1981 gpz550.
Now if the bike is putting out more torque than stock, I can't say what will happen.
Post edited by: loudhvx, at: 2006/07/27 02:01
  • trippivot
  • trippivot's Avatar
27 Jul 2006 05:53
#65102
get a set of clutch springs. they sag first and create slipping. very simple fix
less than 5 dollars for EBC brand-maybe a gasket and oil change also at the time you take the clutch cover off
  • Trav
27 Jul 2006 10:39
#65165
Hmm that sounds like a good idea, trippivot. Worth a shot either way. I was even wondering how much oil would run out if I had the bike all the way over on the side stand and did it that way, heh. It should be due before too long anyway though.
Lou, when you say "stock" clutch disks, do you mean stock spec (or someone who markets them as OEM spec) or literally "genuine kawasaki" clutch disks?
It's not an adjument thing, the cable was new put on by me when I got the bike, and I can loosen it up till it has all the play it needs and then some, but as soon as the clutch cable pulls taunt, the clutch slips. It would say to me that it is in the clutch itself, with disengagment happening so quickly. When I start out, I can let the lever out literally almost all the way before it even grabs at all.
  • hydrolazer
  • hydrolazer's Avatar
27 Jul 2006 11:40
#65179
the way you just described your clutch,,you have it to tight. it disengages when the lever is pulled in..it engages(holds)when the lever is let out. if the bike starts moving when releasing the lever and its at the end of the travel, the clutch plates will slip under a load, the clutch should be adjusted to where its at full holding power before the lever is all the way back out,,hope that helps you some
\'79 kaw 1000 ltd
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
27 Jul 2006 12:09
#65188
I would agree with Trippivot and the tuning shops you have spoken to, use genuine Kawasaki plates only and some aftermarket springs. The EBC springs are about 10% heavier than stock. If you don't mind a really heavy lever action (I don't) then Kibblewhite do some "red" racing springs (they aren't actually red) that are about 30% heavier and will cope with about 150hp.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • RollingStock
  • RollingStock's Avatar
27 Jul 2006 13:17
#65210
stock is the best
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
  • loudhvx
  • loudhvx's Avatar
28 Jul 2006 20:19
#65551
I mean from the dealer,genuine Kawasaki, oem disks. I tried to use brand new stock springs with aftermarket disks and it slipped a lot! The aftermarket disks only grabbed with aftermarket springs which were way too heavy for rush hour traffic.
My motor is stock 550 with a jet kit and Kerker.
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
28 Jul 2006 23:16
#65585
Just curious, what do you use for a clutch, Lorcan? What handles 230+hp?
After the clutch in my Seca Turbo exploded, I went with a Barnett clutch & springs (it was $20 cheaper than the Yammy parts!) It held really well for a long time, but eventually started to slip right before I got rid of the bike.
Trav, if you're going to pull your clutch plates and inspect them, you might consider hitting the steels with some sandpaper if they're glazed.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
