Since it doesn't have a kick starter, it's probably from an 81 or 82 KZ650-CSR. The shift pedal shaft is directly below the sprocket in the 4th pic --- it has a splined end. There is also a clutch pushrod & shift rod nearby.
Do not pull out the shift rod, as it holds the shift forks which will fall down & they are difficult to re-install. Parts diagrams. Partzilla. 1981 KZ650-H1.
Voltage regulator. If you need a reg-rec, you can use one from a late model Ninja 500 or Vulcan 500 (
credit to loudhvx).
good condition units can be found on eebbaayy for pretty cheap. or you could use a mosfet reg-rec.
Ignition coils n stuff. you can use Dyna ignition coils. either the grey 2.2 ohm (
closest match to stock) or the green 3.0 ohm which are also used with the Dyna S ignition system. Related, be sure to clean, check & lubricate the timing advancer under the pulsing coil plate. When turning the crankshaft, use a 17mm wrench on the big nut (
not the smaller/inner 14mm advancer bolt).
Kawasaki service manual.
jarlef z650
. the 1981 KZ650 pdf manual is in the
Files section. w color wiring diagram.
KZ650-H1. KZ650-CSR.
