Bike stuck in neutral while riding
- 750G
26 Jun 2013 09:42
My kz750G left me stranded this morning on my way home. I was exiting on an overpass and downshifting around the spiral, nothing dramatic...Just driving like a good citizen. Towards the end of the exit ramp I began to accelerate, but the bike just revved, like it was in neutral. I can shift through all the gears, up and down, but it just clicks and will not engage in any gear. I would appreciate any insight as to where to begin troubleshooting.
Regards,
Roland
Regards,
Roland
- Motor Head
Re: Bike stuck in neutral while riding
26 Jun 2013 09:57
Clutch? Is the clutch slipping? Otherwise I would suspect shift spring, this would not allow the engagement of the shift pawl.
Post the year and model, someone will post a transmission/ shift diagram. Or you can go to kawasaki.com, and owner info, parts diagrams and look at it there.
- 750G
26 Jun 2013 10:02Motor Head wrote: Clutch? Is the clutch slipping? Otherwise I would suspect shift spring, this would not allow the engagement of the shift pawl.
No clutch slippage whatsoever. Mechanically the bike is sound and there were no telltale signs of anything strange. Its a 1980 KZ750G LTD
- Motor Head
26 Jun 2013 10:10 - 26 Jun 2013 10:11
Have a look at the diagram for the shifting, and look at the spring (#7) that goes between the two pawls, which turn the drum. Could be the spring, or sometimes the pins can come loose and fall out of the drum. Could be something else also, like a fork, but then you should get the gears on it.
Last edit: 26 Jun 2013 10:11 by Motor Head.
The following user(s) said Thank You: 750G
26 Jun 2013 10:12
Check your counter-sprocket to ensure it didn't come loose. Ed
The following user(s) said Thank You: Motor Head, 750G
- 750G
26 Jun 2013 10:29
thanks gang, I'll tear in to it and see what I find. With only 9000 miles, I can't imagine it being anything too serious. It was my grandfather's bike and I know he didn't flog it.
- steell
26 Jun 2013 13:07650ed wrote: Check your counter-sprocket to ensure it didn't come loose. Ed
That would be my suggestion as well. Happened to me a few years ago.
- Jeff.Saunders
26 Jun 2013 14:22
Assuming the rear chain is still there, I too would think it is a loose front sprocket.
www.z1enterprises.com
Z1 Ent on Facebook,
- 750G
26 Jun 2013 14:39
Excellent, I'll check that first later this afternoon. On another note, I got my spokes from z1 and had my rims powdercoated. Turned out really nice, I think.
- 750G
26 Jun 2013 21:10
The nut backed off the counter sprocket, thanks for the help!
26 Jun 2013 21:37
Be sure to install the special lock washer under that nut (see diagram). It is still an "Active" part, so any local or online dealer can order it for you if yours is missing. Ed
Attachment 00000_2013-06-26.jpg not found
- P21
26 Jun 2013 22:21
and there it is a again Ed the winner!
thanks Ed you provide so much to this forum
thanks again :woohoo:
Kawasaki KZ 1000 Police (2002) P21
