Crankshaft Bearing Play???
- sevenfiftyman
17 Feb 2012 20:15
Hey guys. I have a 82 KZ750-E3. Theres a "knocking" in the engine and i suspect that a bearing holding the crankshaft to one of the rods has some play in it. However, before i open the baby up (which i am really not looking forward to), i was wondering if anyone had any advice on some preliminary checks that i have not thought of that might solve the problem. And, if i do have to open her up, i was looking for any websites that could help me through it, since i have only performed this procedure on a car, and would appreciate a guide to work with. thanks for any help.
- tinlizzie37
Re: Crankshaft Bearing Play???
17 Feb 2012 22:25
Hi 750 man, Does the bike knock while running? You can find out by pulling each plug wire one at a time while it's running and the one that's noisy will stop knocking when that wire is pulled. It could also be a noisy cam chain, or clutch basket, it'll keep knocking whether you pull a plug wire or not. Check these all out before tearing into the engine. I would bet that is the problem and not a rod knock. Maybe some of the other guys can add something to this. Bob
Bob KZ 650 E1, En 450
- TeK9iNe
- What did you do!?!
18 Feb 2012 01:36
yeah, turn the idle up and start pulling plugs. Dont forget to ground the plug cap you pull off so that the opposite cylinder will fire.
Good luck.
If the knocking goes away when it gets hot, its probly piston slap.
If it is a heavy clunking from the front bottom end, worse at lower rpm, likely crank.
If it gets really rattly, worse/louder at high rpm - it could be rod@crank/wristpin.
Good luck.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- jordan
18 Feb 2012 13:01
My buddy and I both went through rod bearings on our 750's. My bike acquired a bad knock and felt gutless. Tearing into the bottom end showed that I had spun a rod bearing, one was wedged under the other :S. A year later the same thing happened to my buddy's. But like everyone said, make sure you rule out all possible other options before you dive into splitting cases
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- sevenfiftyman
20 Feb 2012 19:43
It is definitely making a knocking sound. Havent had a chance to pull the plugs and check yet. Although it is an 82 model, it only has 13,300 miles and Im hoping it is something simple. First bike for me so obviously it is sentimental.
