advice on camshafts
  • 79kz1000*
  • 79kz1000*'s Avatar Topic Author
advice on camshafts
16 Feb 2012 15:11
#504412
Anybody use cam motion shafts before? its a z4 grind. Gonna build a 1075 an was wanna to know ur thoughts on this cams?
79 kz 1000 ltd
76 kz 900
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
Re: advice on camshafts
16 Feb 2012 17:58 - 16 Feb 2012 18:00
#504446
The z4's are .420 lift meaning you'll have to go shim on bottom. I'm running APE .410 lift cams in my 1075 and really like them. To really take advantage of a cam that size you'll need some serious head work done too.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 16 Feb 2012 18:00 by andy9802gt.
  • DFIGPZ
  • DFIGPZ's Avatar
16 Feb 2012 19:35
#504456
Cam motion Z4 is a pretty hot cam for a 1075 I have done a couple 1075s with the Z4 cams and Yes you can run them shim on top just make sure your spring pressures are correct and set your valve clearances to .004in on the INT and EX you will be fine the Cam motion manual says largest cam with shim on top retainers.
1984 750 Turbo
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
  • Banned
16 Feb 2012 19:43 - 16 Feb 2012 19:43
#504459
you mentioned in another thread getting LC to do urs, he'll set u up with that anyway
Last edit: 16 Feb 2012 19:43 by jonnybravo.
  • andy9802gt
16 Feb 2012 20:23
#504469
I was told that anything over .410 would actually lift the shim off the bucket because of the way it contacts it not because of lack of spring pressure. I seem to recall it being widely regarded that .410 is the max reccomended lift for shim on top when I built my motor. Not saying dfigpz is wrong just singing the song I know the words to.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • 79kz1000*
17 Feb 2012 01:08
#504525
Thanks for your replies guys
79 kz 1000 ltd
76 kz 900
  • Old Man Rock
  • Old Man Rock's Avatar
17 Feb 2012 09:00
#504555
this may help...
Attachment CamMotionCamsJPG.JPG not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • LarryC
  • LarryC's Avatar
17 Feb 2012 10:15 - 17 Feb 2012 10:20
#504563
If you're going to stay with stock size valves, order them with a 1.080" base circle.
If you're going to go with over size valves, order them with a 1.050" base circle.
Z4 is a nice cam if you like the tach needle heading home a lot when you ride and you're not opposed to flogging the shift lever when required.
If it were me, with a 1075 for the street, I'd get the Z1 grind or K410, some GPz11 38mm intake valves and push some air through the head. Top it off with some RS34's. [because they seem to be easier to get than CRS]
JMO
Larry C.
Last edit: 17 Feb 2012 10:20 by LarryC.
  • andy9802gt
17 Feb 2012 13:04
#504603
LarryC wrote: If you're going to stay with stock size valves, order them with a 1.080" base circle.
JMO
That sounds famaliar! B) It does make for a fun ride.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • DoubleDub
  • DoubleDub's Avatar
17 Feb 2012 14:42
#504633
JMO
Hey Larry - (sorry to Hijack) have you checked on the Keihin's lately? I saw Dynoman had some listed as not available for a bit, but his inventory seems to have replenished - is it possible that the Keihin supply lines are back up and running?
  • LarryC
  • LarryC's Avatar
18 Feb 2012 11:03
#504840
JMO
No, I haven't. I got so frustrated with waiting on them I gave up after the quake in Japan. Maybe things are getting better now. I hope so :)
Larry C.
The following user(s) said Thank You: DoubleDub
