performance exhaust for kz and gs
  • spondonz1
  • spondonz1's Avatar Topic Author
Re: performance exhaust for kz and gs
17 Feb 2012 11:55
#504589
steveo_4192003 wrote: Take a pic of the pipes off the bike so we can see head pipes!
What do you want to see?
Headers are conical from 37mm to 40mm inside diameter flowing into the special collector.
Everything made in Stainless Steel, even the spigots in the head and springs.
You don't find that on a mass produced exhaust.
  • Kawickrice
  • Kawickrice's Avatar
17 Feb 2012 13:39
#504613
Those pipes will look killer on my Stagecoach B)
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • mtkawboy
  • mtkawboy's Avatar
17 Feb 2012 19:04
#504710
Extremely nice looking and Im sure working but Im not taking my pipes loose every time I change the oil. Or do my 67 year old eyes decieve me ? I'll have to stick with my Kerkers also for that price although Im sure they are worth every penny but SS checks dont allow pipes like that for me. Last but not least would be the freight for them from Japan or the Netherlands, wherever they are made on top of the $1145 for a box that size.
  • VenturaRider
  • VenturaRider's Avatar
17 Feb 2012 19:23
#504716
Can somebody please explain what springs hooked to a flange that is bolted exhaust side of the head do? :unsure:
Box stock 75 Z1900
74 Z1900
Ventura Ca.
  • Kawickrice
17 Feb 2012 19:41
#504720
VenturaRider wrote: Can somebody please explain what springs hooked to a flange that is bolted exhaust side of the head do? :unsure:
I believe there is a flange that bolts to the motor and the pipe is held on the flange with springs. Thats the way the two strokes are anyways.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • VenturaRider
17 Feb 2012 19:54
#504724
Isn't the bolted flange suppose to compress the gasket in the exhaust port and if so whats the point of the spring?
Box stock 75 Z1900
74 Z1900
Ventura Ca.
  • Kawickrice
17 Feb 2012 19:58
#504725
If you look at the pic it looks like a separate piece bolts to the motor and the pipe slides onto or into the flange. It is not one piece
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
17 Feb 2012 20:14
#504728
So it looks like to remove the pipe from the cylinder head you would just unhook the spring and pull the pipe out of the flange. I guess it must be a pretty snug fit between the pipe and flange to prevent exhaust leaks unless there's some type of gasket in the flange. Ed
  • VenturaRider
17 Feb 2012 20:16
#504730
If the spring is creating the gasket compression would you not want a second spring on the underside of the headpipe for equal compression of the gasket mating surface?
Box stock 75 Z1900
74 Z1900
Ventura Ca.
  • Kawickrice
17 Feb 2012 20:17
#504731
It is a slip joint that is used in many applications. No different than a megaphone slip joint
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Kawickrice
17 Feb 2012 20:18
#504733
VenturaRider wrote: If the spring is creating the gasket compression would you not want a second spring on the underside of the headpipe for equal compression of the gasket mating surface?
The piece with the bolt flange crushes the gasket and bolts solid, the pipe slips onto it and is held with springs
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • VenturaRider
17 Feb 2012 20:29 - 17 Feb 2012 20:31
#504737
OK I get it. Its a case of the dreaded hidden slip joint. :blush: I'll blame my ignorance on bad photography.LOL :lol:
Thanx for your time and explanation.
Box stock 75 Z1900
74 Z1900
Ventura Ca.
Last edit: 17 Feb 2012 20:31 by VenturaRider.
