Do oil coolers really work?
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Do oil coolers really work?
05 Feb 2012 09:40
#502185
Reference to title question, "Do they work"... Yes!
As for do you need one, who the hell knows all depends on your bike/build and where you live (internal/external temps).
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • testarossa
  • testarossa's Avatar
05 Feb 2012 10:19
#502194
OMR's chart provides a definitive answer to the question about their effectiveness. One thing that jumps out at me is the 16 degree increase in temperature at the exhaust outlet. I wonder if there was a tuning difference that led to a change in EGT or did the addition of the cooler alone produce this?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • faffi
  • faffi's Avatar
05 Feb 2012 11:21
#502202
A 200+ degree drop in cylinder head pipe temps sounds way too much, and the exhaust header temp drop also sounds strange to me, but then again I'm no engineer. It's also strange to see the inlet temps being about the same as the outlet side considering that fuel constantly cool the inlet side and hot gasses constantly heat the exhaust side, but I guess there are reasons for this that I do not understand.
The drop in oil temp is very reasonable and is what I would be concerned about. In general, we do not have temps high enough nor speed limits high enough to warrant a cooler, but if I did a lot of hard running and/or idling in traffic in a warm climate, I would definitely add an oil cooler. And even if you do add a cooler that you rarely need, you can cover it up most of the time to prevent air flow and just leave it open when needed.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
  • Old Man Rock
05 Feb 2012 11:37 - 05 Feb 2012 11:41
#502203
Keep in mind all, laser temp guns can be tricky/deceiving due to angles (reflected light vs refracted back to the gun)....
The key notes in those measurements are as follows...
* All FLUKE Bead measurements are accurate (oil temps). ;)
* Laser "Cover" measurements will be fairly accurate due to decreased angles, aimed right at the cover.
* In noting the intake & exhaust ports, assumption is fairly accurate due to minimal measurement change in the intake side for this wouldn't change but the exhaust side would due to decreased operating temps, kinda makes sense...
As for the exhaust pipes, hard to say due to angles, not sure I buy the large change either but these are the measurements obtained with the laser temp I recorded...
The biggest thing for me is the oil temp, here in AZ @ summer temps of 110-118F, oh yeah huge change in oil temp thus engine temps... Must needed here in Hell! :laugh:
Just in case interested, tools used...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Feb 2012 11:41 by Old Man Rock.
  • dano83-1100
  • dano83-1100's Avatar
  • 1983 KZ1100 LTD
10 Apr 2012 11:26 - 10 Apr 2012 11:31
#514999
reading an article on this very topic with Cycle "experts" from the racing world. They said the reason the race bikes had them was becasue they had such high temps the oil would literally boil otherwise.
Also this was more for clutch working properly than to cool the engine in any way. It does not cool the engine. The AIR cools the engine...these are AIR COOLED bikes.
If a bike is stationary on a dyno it will get much hotter than if it is going around the block. I am not a mechanic, nor a scientist so I am sure that oil coolers work at keeping the oil a cooler temp so that it doesn't break down as fast and the viscosity that is needed to run the bike is kept more consistant...as far as cooling the engine...I don't believe it. water cooled bikes have a radiator, and the liquid is pumped through the engine case to keep it "cool".
Oil coolers don't work that way...the oil is internal and i don't believe that they were created for this reason. just my humble opinion. Honestly I would ask a Kawasaki mechanic who works on a racing team with air cooled bikes for this answer.
Last edit: 10 Apr 2012 11:31 by dano83-1100.
  • DoubleDub
  • DoubleDub's Avatar
10 Apr 2012 11:47
#515003
Sorry, that's just not correct.
Oil is pumped, just like coolant. The reason it boils is because it's drawing heat out of the engine, it doesn't just heat up spontaneously. The engines are both air and oil cooled.
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
10 Apr 2012 16:40 - 10 Apr 2012 16:57
#515068
OMR, I graphed your readings in a crude spectral format. Some interesting stuff there. Can you repeat these tests to give a more statictically sound look? Also, can you verify your IR gun readings with your contact thermometer? I have a healthy distrust in those IR guns as the emissivity of different materials can throw them off at different temps. Is 370 the max scale on your IR gun at an emissivity of 1? Interesting that the oil in the case only changed a few degrees and yet you see that huge difference in temp at the "pipe". Can you show us that location? The reason I am so curious is I live in Phoenix (Chandler) as well and I don't ride my KZ in the hottest months because I don't have a cooler but I want one but have heard so many conflicting opinions. I would like to repeat your tests when it gets to face melting temps here to see what different oils, coolers and some other variables will have on the temp and performance of the bike.
Last edit: 10 Apr 2012 16:57 by DiamondSkyBlue1000.
  • Medina
  • Medina's Avatar
20 Apr 2012 21:37
#516986
Old Man Rock wrote: Reference to title question, "Do they work"... Yes!
I'd have preferred to see a chart done apples to apples- seems temps and dyno oil were checked against cooler and synthetic.
I cant find the chart I found on the net showing 4 engines on a dyno and all they compared were dyno to synth. Fake oil ran quite a bit cooler
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
  • jdbusch
  • jdbusch's Avatar
30 Apr 2012 17:42 - 30 Apr 2012 17:42
#518851
thinking about putting this oil cooler on the 1100-A3 does anyone see potential problems?
gonna relocate the horns and mount it between the exhaust and the wire loom holder on the frame ( sticks out toward the front just below the triples).
Oil Cooler, 7 1/2 in. x 12 in. x 3 7/8 in. Cooler, 7 in. Fan, 1/2 in. Hose Barb Fittings
www.summitracing.com/parts/DER-15830/?rtype=10
Current:
1983 KZ1100-A3 Shafty
Gone:
1979 KZ1000-E Shafty
Email:
jdbusch1978@hotmail.com
Last edit: 30 Apr 2012 17:42 by jdbusch.
  • MFolks
  • MFolks's Avatar
30 Apr 2012 18:00
#518853
  • jdbusch
  • jdbusch's Avatar
01 May 2012 01:52 - 01 May 2012 01:56
#518973
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationi kind like the looks of this. wonder how well it works.
or
Current:
Gone:
Email:
Last edit: 01 May 2012 01:56 by jdbusch.
  • MFolks
  • MFolks's Avatar
01 May 2012 02:14
#518976
I'd think either would work, the latter having twice the cooling surface area. Now to figure out how to secure it to the bike.....
