Is the gas cap supposed to vent?
  • Flyndrive
  • Flyndrive's Avatar Topic Author
24 Sep 2011 20:22
#479268
I have found out that when I ride the fuel stops flowing after a little while. I look down at the fuel filter and it is empty. The tank is creating a vacuum and stopping the fuel. I finally found out that if I open the gas cap for a second the gas flows into the filter. I can run with the gas cap NOT fully latched so that it vents air into the tank, then it runs great.
Is the gas cap supposed to have a vent to keep from building a vacuum in the tank? I don't want to ride with my gas cap open all the time.
1980 KZ 550A1
1985 GPZ 900R
  • wireman
  • wireman's Avatar
Re: Is the gas cap supposed to vent?
24 Sep 2011 20:23
#479270
yes it has a vent built into the cap area B)
  • MFolks
  • MFolks's Avatar
24 Sep 2011 20:27
#479273
Yes, it should have a venting action, otherwise when out for a ride, the engine will suffer fuel starvation & possibly run lean. Open up the cap, looking for sealing washers/flaps to allow air to get into the tank. You'll probably have to go to either www.bikebandit.com or www.kawasaki.com for a parts breakdown.
  • wireman
  • wireman's Avatar
24 Sep 2011 20:36
#479279
fuel tank cap gasket 11009-1051 $4.98 according to babbits.com anyway B)
  • Motor Head
  • Motor Head's Avatar
24 Sep 2011 20:50
#479284
If you take the cap off, then put it upside down on your work area, take out the two Phillips head screws. Then the center section will come apart. there will be two holes and matching groove for the venting.. make sure that they are clear, clean, etc. Pretty simple to clean it, just be careful with those screws, could be pretty stuck, soak then overnight with PB blaster or something. then one the ones I've done I used a hand impact driver with the correct bit. Came out without striping or breaking.
  • Flyndrive
24 Sep 2011 20:53
#479285
Took the cap apart and the vent goes through the lock. After taking the lock off there was a little 1/32in whole under the edge, beneath the spring loaded seal. I can't believe this little bitty whole has been my whole problem.
Thanks.
1980 KZ 550A1
1985 GPZ 900R
  • ramtough_63
  • ramtough_63's Avatar
24 Sep 2011 20:58
#479287
if your not gonna ride for a couple days take the cap off put it in a small bowl spray it real good with pb blaster or whatevr penetrating oil you have let it soak a while fill it up with CLR and by morning those screws come out like a genie broke them loose in the middle of the night. did the last couple of nasty rusted unusable caps that way tookk a detail brush brushed it off put the new gasket on looked ans worked like new
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • Motor Head
24 Sep 2011 20:59
#479288
Yep sounds like you got it then. It looked to me like a puny little POS design, but it seems to work. Same size vent on a 1100 as your 550. Go figure. Any decent two stroke has a 1/8 line at least, and only 1 carb!
  • Flyndrive
24 Sep 2011 21:42
#479298
I was expecting a larger hole then that or at least more then one hole (so if one got plugged it would still work).
I also found another negative side to the dredded pod filters today. While my bikes was parked today it rained and I think practically filled the #4 carb with water. Need to design some kind of sheet metal sheild over the top that bends down on the sides to keep rain and cross winds out.
1980 KZ 550A1
1985 GPZ 900R
  • Motor Head
24 Sep 2011 21:46
#479299
Pod's= fair weather, I do to much varied riding to even consider those.
Factory Air-Box, with a good flowing filter, Best for street/ everyday riding. Now if your racing on a track? Can you get more power from pods or a Custom Air-Box? I bet Air-Box, you can Ram Air a box pretty easy.
  • TexasKZ
  • TexasKZ's Avatar
25 Sep 2011 19:39
#479492
Pods=fair weather=bs
If you're really in the mood to play with jetting - try this
www.zrxoa.org/forums/showthread.php?t=226528&page=4
  • Polar_Bus
  • Polar_Bus's Avatar
27 Sep 2011 09:53
#479908
On my GPz after I shut the hot engine down, I will actually hear the fuel cap vent emit a very soft "whistle" type venting sound .
Bikes:
'84 GPz1100
'06 HD Fatboy
