Looks like I need to do my RINGS. Anything else?
  • iamkalaniprince
  • iamkalaniprince's Avatar Topic Author
  • You Rule!
28 Aug 2011 18:15
#472353
Aloha all..
Bike = 1976' KZ 900
Mobile motorcycle mechanic says my rings are bad and compression is low causing plugs to foul within 100 miles of riding on new plugs.. I think I'm going to have him change em..
I trust the users of this forum are way more insightful with regards to KZ's then this mechanic so I'm wondering.. Is there anything else you would definitely do when doing a ring job?
Stuff that's been done as of now : Carbs via (wiredG), Electronic ignition, new batt, main fuse box. Would you recommend changing the MAIN wiring harness?
Much love in advance for any insight : )
Attachment kz.PNG not found
  • MFolks
  • MFolks's Avatar
Re: Looks like I need to do my RINGS. Anything else?
28 Aug 2011 18:49
#472357
How's the wiring harness look? Not held together with electrician's wire nuts and black sticky tape?
If you're gonna go for new rings, have the valve stem seals replaced too. While the head is off, inspect the sparkplug threads for signs of cross threading. If they're bad, have a shop do some "Timeserts": www.timesert.com/
  • iamkalaniprince
  • You Rule!
28 Aug 2011 19:03
#472358
great advice. The wiring harness seems okbut a couple of the plastic ends have completely fallen off due to the plastic becoming too brittle..
Can the wiring harness be changed without taking the bike apart completely?
  • APE Jay
  • APE Jay's Avatar
28 Aug 2011 19:10
#472359
If you have enough miles on it to wear out the rings, you may as well rebuild the head while it is off.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
28 Aug 2011 19:14
#472360
APE Jay wrote: If you have enough miles on it to wear out the rings, you may as well rebuild the head while it is off.
The voice of experience...follow it. Really.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • iamkalaniprince
  • You Rule!
28 Aug 2011 19:21
#472361
any KZ specialists you'd recommend online or should any proficient mechanic be able to do a good job?
  • iamkalaniprince
  • You Rule!
28 Aug 2011 19:24
#472362
the bikes got 26k but now that I think of it, I remember the previous owner stating that it had recently had a top end job done.. I guess rings aren't part of that :)
  • otakar
  • otakar's Avatar
28 Aug 2011 19:25 - 28 Aug 2011 21:34
#472363
Many people make that assumption on the 96 900. I did also, until I found it to be the choke plungers not seating properly and fowling out my plugs. I repaired the problem inside the carburetors and the problem stopped. I doubt that your rings are worn out unless you don't change the oil regularly and you have 90,000mi on the engine. At 26K on the engine the rings are just broken in, not worn out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 28 Aug 2011 21:34 by KZQ.
  • MFolks
  • MFolks's Avatar
The following user(s) said Thank You: iamkalaniprince
  • MFolks
  • MFolks's Avatar
28 Aug 2011 19:33
#472366
And this: www.pbase.com/mainecruising/wire_termination
(The Good, Bad, & Ugly Wire Crimpers)
  • iamkalaniprince
  • You Rule!
28 Aug 2011 19:44
#472367
gosh, that would be terrible if it was carb related after waiting 6months in wired george's rebuild query..
There is some visible oil on the pistons when shining an LED in there..
could carb issues cause oily pistons?
  • otakar
  • otakar's Avatar
28 Aug 2011 20:11 - 28 Aug 2011 20:12
#472372
Rings will NOT be warn out at 20-30k mikes. Not even close. Wired George is a subject that we do not bring up on here. It will always start a lot of unpleasant emotions among most members here. If you run some combustion chamber cleaner threw the top end of the engine it will clean out most of the crap on top of the pistons.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 28 Aug 2011 20:12 by otakar.
