Air box and oil leak at tach cable
- Redox6022
13 Aug 2011 21:11 - 13 Aug 2011 21:13
Just purchased a 1981 GPz550. It needs a new air box, the previous owner put pods on it, but the jets are stock I think. Do you know what years of GPz's or KZ's are compatible with it? I saw one on ebay that says its from an 1985, and comparing it to the 81's part fiche diagram it looks almost identical. Here is the ebay posting
cgi.ebay.com/ebaymotors/1985-Kawasaki-ZX...fPartsQ5fAccessories
As for the tach cable, is there an o-ring where the cable goes into the head? It's leaking from there and want to fix.
This is my first bike. I have a lot of mechanical experience with cars, but totally new to bikes.
***Could a mod please move this to the carburetor sub-forum? Thanks!
1981 GPz550
Last edit: 13 Aug 2011 21:13 by Redox6022.
Re: Air box and oil leak at tach cable
13 Aug 2011 21:35
According to Kawasaki.com these take the same airbox:
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ550-D1 (GPz) (1981)
The oil leak can be easily fixed by replacing the tach seal, Z1 Enterprises carries them. Their site is hung at this moment, but the link below shows what they look like. Ed
shop.ebay.com/i.html?_nkw=kz550+tach+sea...=p3286.c0.m270.l1313
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
- Redox6022
13 Aug 2011 21:51
Ordered tach seal from Ebay, I'm probably going to get a new air box from kawasakipartswarehouse.com instead of scouring the country for a used one.
1981 GPz550
- Redox6022
14 Aug 2011 01:39
Does the tach cable at the head pull out or unscrew?
1981 GPz550
- MFolks
14 Aug 2011 01:48
At the engine, there should be be a nut on the cable, this connects to a fitting on the engine that spins the tach cable.
14 Aug 2011 07:28Redox6022 wrote: Does the tach cable at the head pull out or unscrew?
On my KZ650 there's a knurlen nut that unscrews and a little plate behind it held on by a screw (see pic).
Attachment Tach-1.JPG not found
- Redox6022
15 Aug 2011 13:14
Mine's exactly the same, I just didn't know if the knurled part unscrewed or if it was just the phillips head screw. Awesome thanks.
1981 GPz550
