extracting a broken off camshaft sprocket bolt!?!?
- captain awsum
18 Jul 2011 18:10
2.bp.blogspot.com/-zrp377V3J3k/TiSfAOCrO.../CIMG0442-748161.jpg
any suggestions? The camshaft sprocket bolt broke off, my click-stop torque wrench didn't click...and broke off the head
I have a project 78 kz400c1 (currently in pieces)
www.kz400.blogspot.com
- MFolks
Re: extracting a broken off camshaft sprocket bolt!?!?
18 Jul 2011 18:19
Get some PB Blaster,Kroil, or other good penetrating oil & soak the broken piece for a few days. While doing so, get some left handed drill bits(the kind that cuts turning backwards from a regular bit) & drill out the broken piece. Just the action of drilling will sometimes remove the broken bolt.
Most machine shop supply stores should have what you'll need.
Here's some Sears Craftsman removal kits:
Craftsman 10-Piece Drill-Out, Micro Standard Drill-Out and
Screw-Out Set With Case
#009-52158
Craftsman Screw-Out 3-Piece Damaged Screw Remover
# 009-52154
#009-52158
# 009-52154
- TeK9iNe
- What did you do!?!
18 Jul 2011 22:23
Yup, good advise.
hlaf and half, atf and acetone is the best penetrant in the world.
Heat the part and pour some on, it will suck right in to it
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- steell
19 Jul 2011 09:36
A bolt, broken off in a through hole, that's threaded all the way through, I think left handed drill bits would be a waste of money
Try a regular right handed drill bit on the front to see if it will screw the bolt on out the back, if that don't work try the drill on the back side to see if you can unscrew the bolt.
If that fails, try a small punch and a hammer to try and rotate the broken bolt so it either goes on through or backs out.
If it's close enough to the surface you could use a small cutting wheel on a Dremel to cut a slot in the end and unscrew it with a screwdriver.
Bolts that break because of over tightening generally screw right out, no need for the chemical gymnastics
- MDawnz1
22 Jul 2011 03:03
I agree with Steell, use a drill bit smaller then the threads (check one of the holes without a broken bolt)
Center punch just right ,start to drill until its cutting then lean on it and just drive it out the other end.
PS , PLEASE don't forget to use a vice to hold it AND tape off the cam where you chuck in it in.
1974 Z1a, still 903
