Exhaust manifold repair?
- section8joe
30 Jun 2011 11:40 - 30 Jun 2011 11:41
Got home from a trip and notice and exhaust leak from the exhaust manifold. Pulled the exhaust off and the exhaust flange wore a grove into the exhaust manifold. What are my options for fixing this? Can I it filled with weld and file it down? I also need to buy new exhaust inserts(not sure it thats the correct name) They are the removal inserts that go into the exhaust pipe. Can I get them from Z1?
Attachment 5887950298_e5032bb49f_z.jpg not found
Attachment 5887384593_743bdbd599_z.jpg not found
79 kz750b4
Last edit: 30 Jun 2011 11:41 by section8joe.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
Re: Exhaust manifold repair?
30 Jun 2011 12:47 - 30 Jun 2011 12:48
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationPlease add your bike info to your signature line, it helps others to give you correct info.
Your 79 KZ750 is what I'm assuming, the gaskets are available from Z1E.
Linkus
The broke out section could be welded by a good welder that is good with aluminum. Might be about the same cost though as to do a head replacement from a parted out bike.
Linkus
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
Last edit: 30 Jun 2011 12:48 by KZ_Rage.
- section8joe
30 Jun 2011 13:21
Yeah, it's a 79. I updated my profile. the insert Im looking for is a two pieced kind of a flange. I'll check z1 for it. Thanks for help. i know a few professional welders so think were gonna go that route. I just wanted to know if if was do able.
79 kz750b4
- Mark Wing
01 Jul 2011 22:38
If you know welder then just have it welded, he can do it in the frame. He can weld it up against a new flange as the aluminum won't stick to the steel. My fix was different but it's working fine.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- z1kzonly
01 Jul 2011 22:50By the looks of that white, clean exhaust port!section8joe wrote: Got home from a trip and notice and exhaust leak from the exhaust manifold. Pulled the exhaust off and the exhaust flange wore a grove into the exhaust manifold. What are my options for fixing this? Can I it filled with weld and file it down? I also need to buy new exhaust inserts(not sure it thats the correct name) They are the removal inserts that go into the exhaust pipe. Can I get them from Z1?
Is that running very lean?
Maybe it was so hot it did a meltdown.
- wireman
04 Jul 2011 02:00
as long as the gasket seals against the head surface i think you could just clean up the area and reinstall your exhuast with new gaskets and split collars.
id check out the carbs/tuning while youre at it though to find what caused the problem
