1975 Z1B, Review of Replica 4 in 4 exhaust pipes
- luc
22 Jun 2011 17:11 - 22 Jun 2011 22:57
2 of the factory pipes ( factory but 76 pipes) got stained by battery acid ( my AGM battery died during a long trip and the only replacement availabe was a 'regular" battery with a vent) so i decided to buy a set of new pipes from Jeff ( Z Enterprises)
They arrived in a big box and very well packed, buble wrap, peanuts, and each pipes covered in foam and cling wrap.
I carefully inspected each pipes and could not find any defect, scratch or blemish.
The quality of the chrome and especially the welded seams are MUCH BETTER than the Kawasaki that i had on my bikes.
On the Kawasaki the seams were not even but more like the teeths of a saw blade, the replica are very smooth and even.
They fit perfect with no "adjustment" needed.
The only thing "wrong" but very minor was the chromed Allen screw used for the baffles, replacing them with regular 6mm bolts took only a couple of minutes.
All in all a GREAT product with ( as always ) a great customer service from Jeff
I should add that the exhaust gasket That I also ordered were quite diffrent from the copper ones that I'm used to, they were aluminum, much thicker and with an abesto type material on both sides.
Last edit: 22 Jun 2011 22:57 by luc.
Re: 1975 Z1B, Review of Replica 4 in 4 exhaust pipes
22 Jun 2011 18:18
glad that they exceded your hopes!
thanks for taking the time to write it up.
- mtbspeedfreak
22 Jun 2011 18:24
+1 Thanks Luc! I'm thinking about the 4 into 4 pipes, "just to be different."
2000 ZRX 1100
1976 KZ 900- Daily Driver
- peter1958
- Banned
22 Jun 2011 19:31
They are nice pipes , I bought a set for my 75z1b aswell and i`m very pleased
www.kzzone.com/
- tybolt99
- From where KZs came
22 Jun 2011 22:20
That's what I need to get next.
Thank you for your review.
Sounds like a winner.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- trianglelaguna
22 Jun 2011 22:44
Great review....how bout some pics ...peter too..????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Kidkawie
- I bleed premix
23 Jun 2011 12:03
I'd like to get a set of those someday, lets see some pics!
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- Mcdroid
- Gone Kwackers
23 Jun 2011 12:15 - 23 Jun 2011 12:17Kidkawie wrote: I'd like to get a set of those someday, lets see some pics!
Also on my 'To Buy' list from Z1Enterprises, amongst many many other items
BTW, those 'wafer' gaskets are Yamaha gaskets and they work rather well as replacements...the only drawback being you can't anneal and re-use them.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 23 Jun 2011 12:17 by Mcdroid.
- mtkawboy
23 Jun 2011 14:06
I had a new 73 Z1 and if I could give you a piece of advise Id take the baffles out & remove the packing around it. This is what caused the original ones to rot out. They held moisture after short rides. Also check that the drain hole is clear once a week. The pipes will last a lot longer that way and at the price you definetly want them to. My 2 pennys, take it or leave it.
- Jack
23 Jun 2011 15:30mtkawboy wrote: I had a new 73 Z1 and if I could give you a piece of advise Id take the baffles out & remove the packing around it. This is what caused the original ones to rot out. They held moisture after short rides. Also check that the drain hole is clear once a week. The pipes will last a lot longer that way and at the price you definetly want them to. My 2 pennys, take it or leave it.
And boy does removing those baffles & packing ever sound good ! Better than most 4-1's for my .02
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- etbike3135
23 Jun 2011 17:35
Luc,
Check you private messages.
Tom
Tom
1973 Kawasaki Z1
18 years in dragbikes
- peter1958
- Banned
24 Jun 2011 07:57
www.kzzone.com/
