how do you clean the oil sight glass?
- btchalice
05 Jun 2011 19:34
mine is dirty on the inside and carb cleaner did little to nothing to it
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- bountyhunter
Re: how do you clean the oil sight glass?
05 Jun 2011 20:44
I had to take the side cover off then scrub it with a very thin brush from the inside (modeler's brush) and spritz it with carb cleaner spray.
06 Jun 2011 00:45 - 06 Jun 2011 00:45
i used an L-shaped pick and stuffed the seem of a red rag in the hole then used the pic to wipe it around.seemed to work out for me.
Last edit: 06 Jun 2011 00:45 by 531blackbanshee.
- otakar
06 Jun 2011 00:56
I just pulled off the clutch cover and popped out the sight glass to clean mine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
06 Jun 2011 04:38
That's just too easy.....
06 Jun 2011 09:44otakar wrote: I just pulled off the clutch cover and popped out the sight glass to clean mine.
i worry to much :blush: .
mine wasn't leaking so i did not want to disturb the seal.
- otakar
06 Jun 2011 11:48
It is no problem at all, it will not leak. The only thing to remember is to push it out with a piece of wood or plastic. Do not use metal. I just take a 2" piece of paint stirrer cut to the same size as the slot behind the glass. I than place it in the slot and turn the cover so I am looking at the sight glass. Than I start exerting slow and steady pressure against a flat surface until the glass pops out. I have removed about 12 that way when I was Gun-Koting my covers because you have to bake the stuff on at 325* after application. The glass with the seal still went in with some resistance when I replaced it afterwards.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
06 Jun 2011 13:13
thanks for that info otto,i won't be scared next time.
- hocbj23
06 Jun 2011 15:33
I put a new sight glass in mine and in 6 months it looked as bad as the old one.Losing battle I think.Lol.bj
- otakar
06 Jun 2011 15:41
The glass will ONLY get that way if you get water in the oil for some reason.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- andy9802gt
- If it tastes that good, eat it yourself.
06 Jun 2011 16:18
My new one fogged up when I first ran the new motor and I was totally diagusted, then the day I thought I had had enough it was clear. Hasn't fogged up since.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
