GPZ1100 head
  • notaduc
  • notaduc's Avatar Topic Author
GPZ1100 head
04 Feb 2011 15:03
#428488
So, what is differnt that makes this a higher flowing head?
1980 (mostly) KZ1000
  • MFolks
  • MFolks's Avatar
Re: GPZ1100 head
04 Feb 2011 16:15
#428505
Smoothing of the intake and exhaust ports at the factory.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: GPZ1100 head
04 Feb 2011 16:54
#428520
depends on which gpz1100 youre refering to B)
  • larrycavan
  • larrycavan's Avatar
Re: GPZ1100 head
04 Feb 2011 16:57
#428523
www.flowbenchtech.com/porting/CRH/kz-data.htm
  • notaduc
Re: GPZ1100 head
04 Feb 2011 18:56
#428596
the 83-85
  • larrycavan
Re: GPZ1100 head
05 Feb 2011 05:02
#428672
What bottom end is it going on? KZ or J?
What's the intended use of the bike?
  • Polar_Bus
  • Polar_Bus's Avatar
Re: GPZ1100 head
07 Feb 2011 04:03 - 07 Feb 2011 04:04
#429125
notaduc wrote:
the 83-85
I have an '84 SUB head and I can tell you it's not the best "street" head. You give up some street "versatile" midrange torque. However at the dragstrip where that head can really breathe now you have the advantage. My GS1100E has a bit more midrange "roll on" torque than my GPz. But get the GPz up around 9K, and that engine really starts to haul the mail !!
Bikes:
'84 GPz1100
'06 HD Fatboy
Last edit: 07 Feb 2011 04:04 by Polar_Bus.
  • otakar
  • otakar's Avatar
Re: GPZ1100 head
07 Feb 2011 05:23 - 07 Feb 2011 09:59
#429133
I don't know about that, I have one on my bike that is flowed to the teeth and running .420 lift cam. I love mine. It runns like a Raped Ape. and YES I am useing BS34s on it. ;) The trick is to match the cams propperly. My cams are asimetrical and the exhaust cam is retarded. This gives me better lower rnd torque.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 07 Feb 2011 09:59 by otakar.
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: GPZ1100 head
07 Feb 2011 05:41
#429136
otakar wrote:
I don't know about that, I have one on my bike that is flowed to the teeth and running .420 lift cam. I love mine. It runns like a Raped Ape. and YES I am useing BS34s on it. ;) The trick is to match and the cams right. My cams are asimetrical and the exhaust cam is retarded. This gives me metter lower rnd torque.
lol, you're retarded :woohoo:
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: GPZ1100 head
07 Feb 2011 06:43
#429140
I too, am retarded :P
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • larrycavan
Re: GPZ1100 head
08 Feb 2011 05:05
#429342
BINGO!
It's the RIGHT cams that make or break the deal.
Stock vs Stock, the situation is exactly like Polar describes it. GS is a mid range monster and the GPz likes to be twisted up..... Kawasaki's are like that, they love RPM.
Nice combos:
Push that GPz head from 83 to 95cfm. Swap out the GPz cams for something like Cam Motion Z1 and you'll transform the GPz into something that will put a smile on your face constantly.
Top it off with a rack of CRS33, RS34 or Pogue Machine taper bored throttle bodies with adjustable pressure regulator..... Can't go wrong with any of those choices.
You want "crap your pants" upper RPM pull & willing to sacrifice some lower midrange.... go with Web 109 grind.
I've seen 81GPz11 run 10.80s with porting and swapping out the EFI to 29 smoothbores. And that was without a bar or slick. Stock cams, pistons...only head and carbs.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: GPZ1100 head
08 Feb 2011 07:50 - 08 Feb 2011 07:51
#429368
Not 1100 related, but with my experience, top end power is limited with just bigger carbs(CV30 from TK27), and a +3mm bore kit(615) on my GPz550. Stock intake and exhaust valving, cams, RD Springs, APE Rebuild, and mild hand porting with combustion smoothing. Even with the 615 kit I've resulted in going from 27 to 36 ft lbs of torque. Next on the list is installing a set of Megacycle Cams(Stage 3), and degreeing them. I'm intake and exhaust breathing limited, so these cams will hopefully add to the top end, and gain even more midrange.
It all depends on where you want the power to come on.
Some day I'll have to 1/4 mile this bike. All stock, including airbox and exhaust, it will run 12.74 @ 104 mph, as my friend did this consistantly.
Carry on, this is good reading. I've subscribed! B)
'85 GPz550(ZX550-A2)
Last edit: 08 Feb 2011 07:51 by CoreyClough.
