ZR7S Exhaust
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: ZR7S Exhaust
15 Oct 2011 19:35
#483388
Rob,
I think that you have a system from a 96 to 99 ZX750- Ninja. There were several different models/ versions but I am pretty sure that pipe came from one of them. Check out this link
www.powersportsplus.com/parts/search/Kaw...ER%28S%29/parts.html
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • rstnick
  • rstnick's Avatar
Re: ZR7S Exhaust
15 Oct 2011 20:42
#483401
Thanks Bruce for the info.
I think you've found the model this came off of.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • gd4now
  • gd4now's Avatar
Re: ZR7S Exhaust
15 Oct 2011 20:53
#483403
Glad to be of help. As to the connection at the head, I do not think they use the split collars, rather just a gasket, washers and nuts to hold them via the attached flanges. I think the issue is do the holes on the flanges match up with the stud locations on the 650 as I am pretty sure the pipes are spaced correctly to fit just not sure about the stud locations.
1977 KZ650 B1
  • martin_csr
  • martin_csr's Avatar
Re: -
15 Oct 2011 21:33 - 15 Feb 2013 11:56
#483409
Last edit: 15 Feb 2013 11:56 by martin_csr.
  • rstnick
  • rstnick's Avatar
Re: ZR7S Exhaust
15 Oct 2011 23:07 - 15 Oct 2011 23:09
#483429
I was hoping to.
Niether of my bikes are at home, so I can't test fit it.
But I understand what you mean about the ZX engine tilted forward.
Bruce, I was worried about the stud locations as well.
The 1&4 pipe flanges look to have the stud holes at 3&9 O'clock, which I'm sure the 650s don't have.
I should ask the guy I got it off of if he tried to fit it to his 650....
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 15 Oct 2011 23:09 by rstnick.
