dry clutch kit
- turboguzzi
dry clutch kit
30 Oct 2010 00:44 - 30 Oct 2010 00:45
hello Zeders
Racer build is in full swing now, will finally post some pics when the frame is back from the welders and there's something to see at last...
In the meantime, came across this picture showing a 83' wayne replica. I am not really sure it's the original wayne bike as its got CV carbs, the racer had Keihin Cr's as far as i know, but i might be wrong.
In any case what caught my eye is the dry clutch kit on it.
Is anybody aware of dry clutch kits for the 750?
Cheers
TG
Cheers
TG
Last edit: 30 Oct 2010 00:45 by turboguzzi.
- Polar_Bus
Re: dry clutch kit
30 Oct 2010 05:21
That's a trick pic of a Gpz !
I also remember a buddy of mine years ago, had a poster of Eddie Lawson on his '81 KZ1000R It also had a dry clutch, and it was also a trick "monoshock" rear suspension setup (even though the production KZ1000's were twin shockers)
Bikes:
'84 GPz1100
'06 HD Fatboy
'84 GPz1100
'06 HD Fatboy
- larrycavan
- kopcicle
Re: dry clutch kit
30 Oct 2010 18:00
...or those forks , calipers , rotors
period pieces they may be but even in their day a difficult proposition at best and just frightening the rest of the time .
A little less unsprung weight on that front axle and bit stiffer front would have gone a long way to making that a real machine .
~kop
~kop
"There are two major pressure changes in a four stroke internal combustion engine , when you light the fire and when the rods exit the block..."
- testarossa
Re: dry clutch kit
30 Oct 2010 20:48 - 30 Oct 2010 20:48
larrycavan wrote:
c'mon Larry, dry clutches are fun. They are the best part of a Ducati. I mean you spend $16K on a bike and it sounds like it's broke when it's brand new. :laugh:
You don't want a dry clutch
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 30 Oct 2010 20:48 by testarossa.
- larrycavan
Re: dry clutch kit
31 Oct 2010 06:51
testarossa wrote:
:laugh:
larrycavan wrote:You don't want a dry clutch
:laugh:
- turboguzzi
Re: dry clutch kit
01 Nov 2010 12:30 - 01 Nov 2010 12:35
hei kop,
well, in italian vintage racing, you have to use period pieces, no modern brakes or suspension mods are allowed unless they were in use back at the time. And you'll be surprised how well they can work if you set them up right. I know that AHRMA is more relaxed in chassis mods allowing 17" wheels and four pistons calipers, but if you ask me, they look out of place on an early 80's bike, but that's me.
in any case, traced down a few other pics of wayne's 83' bike and indeed it does have a dry clutch kit but now I am starting to think that those were some special KHI pieces and not a kit sold over the counter.
The theory behind dry clutches is that they can cope with higher torque while weighting less. there are quite a few kits out there for vintage racing, the one for the CB500T is quite common.
tnxs anyway
TG
tnxs anyway
TG
Last edit: 01 Nov 2010 12:35 by turboguzzi.
- turboguzzi
- larrycavan
Re: dry clutch kit
01 Nov 2010 13:00
Funny how almost all serious racing engines have CR carburetors on them
Re: dry clutch kit
01 Nov 2010 14:11 - 01 Nov 2010 14:23
turboguzzi wrote:
And perhaps another factor could be that the clutch spins with less drag through air than through an oil bath.
Thanks for the excellent engine pic.
Interesting oil routing.
Last edit: 01 Nov 2010 14:23 by Patton.
- turboguzzi
Re: dry clutch kit
01 Nov 2010 17:20 - 01 Nov 2010 17:21
Had good experience in the past with direct oil lines to the cam and plan to do the same in my GPZ build.
Zero oil leaks in the head o-rings and the oil doesnt pick up more heat while its making its way up slowly through the block and head.
And yes, gonna run CR's too
TG
TG
Last edit: 01 Nov 2010 17:21 by turboguzzi.
- Old Man Rock
Re: dry clutch kit
01 Nov 2010 17:21
"Funny how almost all serious racing engines have CR carburetors on them"...
Now Larry, be nice... That's because all the KZR guys have all them BS 34's in their rides... None left for the serious racing machines....
:evil: :whistle: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
