Cheap Source of ZDDP (Zinc) ?
- bountyhunter
01 Jun 2009 23:44 - 01 Jun 2009 23:47
The Material safety data sheet for STP oil treatment says it has zinc compounds, and the cans I have say on the label they contain ZDDP. I wrote the company and asked how much is in it, and received this reply:
That actually agrees with the MSDS data: it says the amount of Zinc compounds is about 2 - 5%. If it's about 2%, (and is added to four to five quarts of oil) would put the zinc level at about 2000 - 3000 PPM ballpark.
Anyway, it's interesting because it's cheaper than the ZDDPlus stuff that is $10 per treatment.
Thank you for contacting us about your STP Oil Treatment.
The amount of ZDDP in our product is proprietary. However, I can tell you that when you add one bottle to four to five quarts of oil, you have the same protection the older motor oils provided. Many classic car owners with flat tappet cam motors use our product for this reason. I hope this helps you.
Last edit: 01 Jun 2009 23:47 by bountyhunter.
- AXL
Re: Cheap Source of ZDDP (Zinc) ?
02 Jun 2009 02:25
what does the zinc/zddp do for the engine? if you run synthetic do you still need to add zinc?
- riverroad
- 1980 1000LTD B4
02 Jun 2009 05:59
AXL, I'm going to assume that ZDDP acts in oil, like lead used to act in gasoline. Lead in gas was used to help lubricate and provide a shock barrier to the moving parts, (besides increasing the octane rating).
This is interesting, because I was never a big fan of STP. Back in the day, to some it was considered to be the stuff you poured into high mileage cars to quiet down the lifters and thicken up the oil so it didn't pass around the worn out rings so it wouldn't smoke as much. Unscrupulous used car salesman bought it my the case. Rebuild in a can, some called it.
So I guess my good old Castrol GTX ain't cuttin it no more?
- JMKZHI
02 Jun 2009 06:09 - 02 Jun 2009 07:03
The phosphorous in ZDP or ZDDP (Zinc DialkylDithiophosphates) acts to prevent metal-to-metal contact. Shell Rotella-T, Chevron Delo & other diesel motor oils have higher levels of ZDP than regular car oils.
Last edit: 02 Jun 2009 07:03 by JMKZHI.
- Mcdroid
- Gone Kwackers
02 Jun 2009 07:03
I just located a local distributor for Penn 20W50 and purchased a case...a bit pricey but it has a very high additive load...so much for GTX
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
02 Jun 2009 08:19
Brad Penn Racing
www.bradpennracing.com/
Jalopy Journal - H.A.M.B. What is with this oil ZDDP content and do I need it?
Replies #17 & #18 have some interesting reading & links.
#28 on pg 2 mentions Valvoline bulletin #2008-300a, but you'll have to go to the the Valvoline website to find it because that link is dead.
- bountyhunter
02 Jun 2009 13:34 - 02 Jun 2009 17:06
AXL wrote:
It bonds with the surface of the metal and forms what is known as a "sacrificial layer" which is sheared off in the cases of metal to metal contact. When the oil pressure is up and the oil is warm, the oil film prevents bare metal contact but during cold start and run after the oil has drained down, there is bare metal contact and the ZDDP reduces wear during this time.what does the zinc/zddp do for the engine? if you run synthetic do you still need to add zinc?
Last edit: 02 Jun 2009 17:06 by bountyhunter.
- bountyhunter
02 Jun 2009 13:37
riverroad wrote:
From what I read, it no longer has ZDDP. It is a very good oil in general, but I think all flat tappet engines need ZDDP.
- otakar
02 Jun 2009 16:03
Here is another source which is a bit cheaper, because one 16oz bottle treats 12 quarts.
www.redlineoil.com/products_motoroil.asp...oryID=1&categoryID=1
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
02 Jun 2009 17:16 - 02 Jun 2009 17:16
otakar wrote:
Interesting. I did a search and found a post about it on another forum saying this:
www.bobistheoilguy.com/forums/ubbthreads...wflat&Number=1149831
For the concentration in the 16 oz bottle.
Assuming you dumped the whole bottle into five quarts of oil, the resulting Zinc levels would be about 900 ppm. I'm not really sure how I could see that one 16 oz bottle treating 12 quarts.
Here is another source which is a bit cheaper, because one 16oz bottle treats 12 quarts. www.redlineoil.com/products_motoroil.asp...oryID=1&categoryID=1
i already taked with dave: zinc 9000ppm and phos 7500 ppm and no moly
Last edit: 02 Jun 2009 17:16 by bountyhunter.
- DoubleDub
02 Jun 2009 19:10
I was planning on using the Valvoline 20w50 Motorcycle Oil in my Kz900 when I fire it up this week. Anyone have a guess what the Zinc/ZDDP levels of this oil are or should I return it and get something else?
- JMKZHI
02 Jun 2009 19:39 - 02 Jun 2009 19:41
Any motorcycle oil should be fine; those & racing oils have more ZDP than regular oils (& about the same amount as diesel oils - sometimes less). I don't recall why, but racing oils may not be suitable for motorcycle or regular car use.
From an MSDS:
VALVOLINE® 4-STROKE MOTORCYCLE OIL CV 20W-50
MOTORCYCLE 4 CYCLE MOTOR OIL
VV743 & VV7430
15. REGULATORY INFORMATION
California Prop. 65
Proposition 65 warnings are not required for this product based on the results of a risk assessment.
SARA Hazard Classification Acute Health Hazard SARA 313 Component(s)
ZINC ALKYL DITHIOPHOSPHATE ... 68988-45-4 ... 1.1108%
From an MSDS:
VV743 & VV7430
California Prop. 65
Last edit: 02 Jun 2009 19:41 by JMKZHI.
