Neutral or First Gear at a Traffic Light ???
- WABBMW
- Let The Good Times Roll !
06 Feb 2013 00:42
I have seen some people stopped at a traffic light with their motorcycles in NEUTRAL, while others keep the bike in low gear, with the clutch lever pulled into the handlebars.
I imagine there are considerations such as wear of certain clutch ot transmission parts. Holding the clutch disengaged might wear the part that pushes on the pressure plate. But having the bike in neutral, and then engaging the gears might be hard on the gear dogs when engaging.
Another angle might be the safety aspect of being ready to react or start off immediately by being in gear.
Does anybody have any recommendations for which method is better? Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Re: Neutral or First Gear at a Traffic Light ???
06 Feb 2013 01:22
Pros & cons. In gear you're ready to go (if your reflexes are good enough) if someone comes up from behind and doesn't look like he's going to stop, but if you leave it in first don't be revving that thing up like a Harley type because if the clutch cable breaks you'll be launched into traffic. I generally put it in neutral. Ed
- trianglelaguna
06 Feb 2013 02:33
whatever you choose...I do both but i leave ten feet between the car ahead and me and watch the car/cars behind come to complete stop and even check the driver in the mirror for idiot....i have moved away and had a car smash into where i would have been ...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
06 Feb 2013 11:33
Neutral if no one is behind me or approaching from the rear & nothing else of consequence from the other directions. Otherwise, 1st gear & ready to do a hole shot. Keep the clutch cable adjusted & lubricated, especially the clutch lever end. I don't worry about wear n tear on anything, but I do think about getting rear ended. I saw a guy get tagged in the rain while he was stopped & attempting to make a left turn.
- baldy110
06 Feb 2013 15:42
All depends on how long the light is.
- pete greek1
06 Feb 2013 15:54
after I'm sure the vehicle behind me is stopped, I'll put it in neutral, & when the opposite light turns yellow, I'll put in gear & be ready for a holeshot when my lite turns green
- 4TheKZ1000
- bluej58
06 Feb 2013 19:35baldy110 wrote: All depends on how long the light is.
+ 1
Normally I'm in gear though
JD
78 KZ1000 A2A
- donthaveakawman
07 Feb 2013 00:07
I had my clutch cable break at a traffic light as i was popping into neutral.
- 893cv
07 Feb 2013 01:01
First gear untill the car behind comes to a full stop, then neutral. I've been hit from behind, the driver skidded over 90 feet before she hit me. Lots of back problems and a broken right hand. If everything is adjusted and lubed correctly there will be no ware on the trans or clutch.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- donthaveakawman
07 Feb 2013 02:39
actually I usually like to avoid traffi.c hours and slow down alot before the light in neutral then coast until the light turns green
- trianglelaguna
07 Feb 2013 02:43
my cable slowly gave out this fall , it gave some warning though ,i had to do a bit of a panic goofy hand key off/brakes while i was lurching out into traffic 3-5 feet...i was first in line at the light...
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
