KZ or not KZ
KZ or not KZ
29 Apr 2009 13:37
Philosophical question:
At what point of modification does a KZ cease being a KZ? Obviously, a tiny little change such as a Halogen sealed beam in place of the stock bulb wouldn’t tip the scales, but if, for example, the frame, swingarm, forks, brakes, bodywork, electrics, etc. were all changed and the engine had aftermarket cylinders, carbs, cams, etc.; would it still be considered a KZ?
- lapeerray
Re: KZ or not KZ
29 Apr 2009 14:01
Will your title still say kz?....
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
- anarki650
Re: KZ or not KZ
29 Apr 2009 14:09
It'll still sound like a KZ and run like a KZ (on steroids) so my opinion is still 100% KZ goodness.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- JMKZHI
Re: KZ or not KZ
29 Apr 2009 14:10
Well, as long as it's got the Kawasaki engine, it'll always be a KZ - I guess.
Re: KZ or not KZ
29 Apr 2009 14:22
if it is still a kz configured engine then i will be calling it a kz,maybe with some monicker in front of or behind the kz.such as "1 bad a$$ed kz"or whetever.:laugh:
leon holmes
leon holmes
- Tyler
Re: KZ or not KZ
29 Apr 2009 14:33 - 29 Apr 2009 14:34
Hmmm lets see...
If you made a titanium frame and bolted in a 400 cubic inch alcohol powered big block. Its still a KZ as long as one part of the orginal bike is still present. There is more soul in one screw of a Kawasaki than any other entire motorcycle. SO there thats my answer...
By the same logic if used one screw form one of my KZ's to put something together on my Mustang it is no longer a Mustang GT, I guess it would have to be a KZ4600GT...
So that is a little extreme but I still stand by my answer. One screw is all it take to make a KZ a KZ!
"74 Yamaha DT 400 Enduro
Last edit: 29 Apr 2009 14:34 by Tyler.
- kaw74z1
- 0 to 60 in 15 minutes.
Re: KZ or not KZ
29 Apr 2009 15:46
....Sounds correct to me
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
- SheffieldSteel
- KZ750E 1981
Re: KZ or not KZ
29 Apr 2009 15:52
My KZ so far has an aprilia rear end and a Honda swingarm. Soon it will have different front forks, but, it will still be a KZ, just a KZ750EAH?
My bike is a 1981 KZ750E with Honda VFR400 NC30 single sided swingarm and Aprilia RS125GP rear subframe and seat pods, engine in more pieces than my mind
Re: KZ or not KZ
29 Apr 2009 16:22
"Will your title still say kz?"
I meant the question from a philosophical perspective rather than legal.
From a legal perspective the VIN that is stamped in the steering neck is used to determine what the MVA will put on the title (at least in MD). So if you put a KZ1300 engine in a Jawa frame the folks at MVA would call it a Jawa :laugh:
- cruspeed
Re: KZ or not KZ
30 Apr 2009 05:55
Here in NC the only way to change a title year/make/model is from rebuilding a salvaged vehicle with or with out a title and that is a long crappy process or completly build one from scratch. You're supposed to notify the DMV if you change engines so they have your new engine serial numbers or frame serial number for vehicle tracking if it gets stolen. Then you will get a new VIN number to stamp on your bike and a new title but will still state the original year bike.
I've made a few trikes from VW's, saturn and a kawasaki T-rex type I'm working on now plus 2 cars and I've found the best way to deal with it is just lie to the dmv and keep your title and get a vehicle tracking system like onstar.
78 KZ1000 project X 2
- timebomb33
Re: KZ or not KZ
30 Apr 2009 05:59
if all that has been changed like a couple of my bikes have been or if you live north of the 48th parralel then they are called the mighty KZed
I THINK MY POWERBAND BROKE
- KawiConvert
Re: KZ or not KZ
30 Apr 2009 07:18
In theory the second you remove a stock kz part and replace it with a non-kz part it ceases to be a kz despite the majority contribution of the other kz parts. This would be the purists view.
In the view that kz's were designed and built to perform, any modification that improves the handling or power of the kz is within the original intent of the design as set forth by the gods of Kawasaki. So long as the motorcycle remains street legal in all 50 states and the title still says kz and the modifications improve handling or performance then its a kz.
However, if a SOHC motor is swapped in, the bike ceases to retain its kz status and is then designated as an oop-z
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
